Cooling Fan dead on mk6 Escort 2.0? HELP!
As a boil over on the M25 has shown me, my fan has packed up of late!
I pulled off the thermoswitch and bridged the terminals and only heard a relay clicking under the dash...and the fuse is ok
Do cooling fans just die?
I've had cars far older and fans worked fine!
Car is an air con model, and have a horrid feeling something could be amiss with the loom, or is that unlikely?
Thanks
Weeksy
Thanks
Weeksy
Hi dude,
I checked in the manual and it didn't list one for the fan which I thought was bloody bizarre!
Car is getting on my nerves! Never had a car boil over on the hard shoulder before!!!
And I have had some real dungballs!
I have it seems to move ok.
Was working only weeks agao dude.
That was my next plan! Not sure I want it to go wired directly or not, means wiring aggro!!
It must have a relay on fuse box right?!
If you put your hand over the battery there is a flimsey plastic panel directly behind it. The relay is mounted to the rear of that. You should be able to see a little metal clip at the top, that's part of the mount.
Rich, I will definitely add one to my toolbox fella, thanks man
MAL, so battery out job to geto to it? You were right about the cost of relays!!
Daylight robbery, at least Dick Turpin used to wear a mask!
23
12-09-2015 12:56 PM
