YB rebuild question
YB rebuild question
Hi. I have in spare engine block with pictons, crankshaft etc. I want to prepare it for installation. How can I know, need to put a new pistons or just new rings is enough? What I need to measure for this? Sorry, In manual I can't find an answer for this question. What is the limit of cylinder wear, how to check it?
*** Sierra RS Custard ***
you need to examine the ring grooves, 5 thou max clearance, you need to measure the piston to bore clearance, 5 thou max again.
Any more than that, and IMHO the pistons arent useable.
Im sure there must be a manual somewhere with exact figures, but those are the ones I used as a ballpark.
I suspect the "proper" piston to bore clearance is probably nearer 2 thou, but at 5 they wont rattle badly, especially if they are the 4wd ones as the pin is offset differently.
But at wich position to measure the piston to bore clearance? in different position in engine block it has different clearance to bore in used engine.
I mean 5 thousands of an inch.
40thou = 1mm
5 thou = 0.125mm
I tend to ignore the top inch or so with worn engines, if its oversize any further down than that though, it will be noisey.
Bottom line is, if you want it right, its new pistsons and a rebore.
anything else is just making do
as I know 4x4 bottom end + 2wd head will reduce c/r. can I put just 2wd pistons into 4x4 bottom end, or I need something else from 2wd versions?
Thanks.
Thanks.
Not easy with hydraulic lifters!
But you need to make sure the valves arent going to hit the pistons one way or another.
The easiest way is that if you have both sets of pistons to hand and it didnt hit on the old set, simply check the existing ones have equally deep cutouts
ok!
Have find mahle pistons on ebay from Woodford Garage Motorsport.
http://cgi.ebay.com/RS-COSWORTH-GENU...em310128686594
I need +0.5mm pistons. Asked them about pistons for 2wd version and received answer "we have 0.5 pistons in stock and there all the same now for 2wd and 4x4". Why now they are the same??? help please.
so, I need to buy new pistons and machine it for standart cr(8)?
7.8(or about 7.85 according head thickness) will be fine with chip(MSD t34, siemens'55) for std engine??
TiB, your advice also to change pistons at 5thou clearence piston-cylinder?
Thanks.
What do you think about cylinder liners? to put it into 200 block, machine it to std size, put old 4x4 pistons(in case of normal condition), new rings etc? may be stupid question, but it can save alot of money
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
