Help cars not boosting properly
08-03-2009, 04:01 PM
Well took my Escos out last night and........ I broke it
Basically I was giving it some stick, got to the top of 3rd gear, and when I changed gear it just didn't boost
So pulled over and no loose pipes or anything, so decided to take it home. It was idling at 2000rpm and when it started coming on boost it sounded like an Impreza.
Now today I've had it out drives fine, idle's fine ect.
But it'll only boost to 10psi then wont rev no higher and sounds like an Impreza until you lift off. Standing still you can rev it through the rev range.
Any ideas what it could be? Maybe a sensor?
08-03-2009, 04:04 PM
poss map sensor sounds like it has thrown a fit!maybe the pipe has a split in it somewhere
08-03-2009, 04:18 PM
RS & ST Parts Specialists
gaz........give us a call need to speak to you anyway mate!!
regards Matt
08-03-2009, 04:20 PM
Ringing now
08-03-2009, 08:48 PM
08-03-2009, 08:50 PM
i presume you have checked all your hoses/vacuum pipes etc
08-03-2009, 08:52 PM
Id check ya map sensor mate.
You still smoking too??
08-03-2009, 08:56 PM
Checked all the pipes yeah, how do I go about checking the map sensor?
08-03-2009, 08:58 PM
And yeah still smoking, just been talking to Lawnsy about it actually.
08-03-2009, 08:59 PM
try another map sensor on will be easiest way
08-03-2009, 09:04 PM
Have you got one in your boot of spares?
08-03-2009, 11:36 PM
I might have one lying about ya can borrow to try
09-03-2009, 05:40 AM
TT T38 Power
No help to you but mine seems low on boost as well
Steve
09-03-2009, 07:18 AM
Steve mines really short of boost, like 18 psi missing
09-03-2009, 07:21 AM
TT T38 Power
Quote:
Originally Posted by
milkman
Mines not that bad thank god LOL, was only holding 1.3 bar instead of 1.7 bar
Yours must feel like standard LOL
Steve
09-03-2009, 07:54 AM
He's probably just not pressing the pedal hard enough
09-03-2009, 08:23 AM
TT T38 Power
BigErn
You saying he's a tart with the loud pedal LOL
Steve.
09-03-2009, 08:31 AM
Errr......... yeah.
09-03-2009, 08:37 AM
TT T38 Power
BigErn
Errr......... yeah.
LOL
Steve
09-03-2009, 02:53 PM
BigErn
You could be on to something there as I've only got little legs
Have you had a dig about for this map sensor mate?
09-03-2009, 06:21 PM
Its in work somewhere, could probably put my hand on it in like
09-03-2009, 06:26 PM
make sure you fuel rail is tight and bolts are in propperly.......
if one has come lose it pushes the injector out when coming on boost and cause's these problems.......then when you lift off it seals again and picks back onto 4 pots...
Go look now...
09-03-2009, 06:27 PM
milkman
ive got one you can try..
09-03-2009, 07:14 PM
Lawnsy im not with the car at the minute, but I'll check tomorrow dinner time and report back
09-03-2009, 09:32 PM
Good lad...
11-03-2009, 09:37 PM
Come on then till everyone what it was........
11-03-2009, 09:40 PM
PF Idiot Sniper
lol something silly or easy?
11-03-2009, 09:54 PM
11-03-2009, 09:56 PM
amal valve plug come off?
11-03-2009, 10:07 PM
Nope..think he is playing in it now so may not get a reply off him for a bit...
Ill let him say what it was...
11-03-2009, 10:12 PM
pipe come off the back of the boost gauge
11-03-2009, 10:20 PM
11-03-2009, 10:29 PM
serious is that what it was!? lol
11-03-2009, 10:33 PM
no it wasnt that, I just found it amusing, although knowing Garys luck this year that would be a godsend. This one was just as easy a fix tho.
11-03-2009, 10:35 PM
yip and i even fixed it with out even seeing the car......
11-03-2009, 10:41 PM
It was what i said a few posts up mate ........when he looked both bolts on the fuel rail were nearly out........nipped them back up and the car is running better than it has for a while......told him to put a drop of locktight on to keep them from coming lose again.......he thought the turbo was gone because of the smoke but was all down to the fuel rail lifting when on boost then resealing when lifting off and picking back up onto 4 pots...
11-03-2009, 10:42 PM
Well I was just about to change the map sensor, and remembered Lawnsy saying check the bolts on fuel rail.
Turns out they'd practically fell out
11-03-2009, 10:43 PM
Could have been awfully nasty if they had. Spraying fuel over on to hot exhaust. Ouch!! Thats why mines a cat C
11-03-2009, 10:45 PM
Id advise anyone to put a drop of locktight on these bolts.........I do....
11-03-2009, 10:46 PM
I needed a bit good luck, fuck me LOL
