zvh to zetec turbo
stage4 2wd cosworth
zvh to zetec turbo
i currently have a fiesta rs turbo with a 1.8 zvh iv had a problem with the engine.
what would i need for a 2l zetec conversion?
i know i need the 2l zetec blacktop or silvertop.
i have,
efi
195 chip
beige injectors
fuel pressure regulator
im gona get a cossie fuel pump.
could i run the zetec off this management or would i need to get magasquirt or omex??
can someone tell me what i need and how i go about the conversion.
what power would this roughly be putting out?
i have,
efi
195 chip
beige injectors
its all down to what you want to spend
as yes you could got to a management of stay with the frs
Colossal Pervert
a 195 chip and beige injectors isnt right for a 1.8 anyway.... or a T3, which I assume you're running....
So you're talking about building a completely new 2L zetec turbo. Cost = thousands. Yes you can run the EEC-IV management, but you'll need injectors and mapping. How much power depends on how much you want to spend - most of what you've already got will not be useable (unless you want < 200bhp). All in all a lot of moolah.
get steve anderson to put a mega squirt and he builds them all the time matedrummys s1 was rapid and so was steves black s2 that was blowing evos and scoobies clean off the road
stage4 2wd cosworth
ye ano mate drummys needed bigger injectors and set up properly tho.i no i wasnt running the right management for the 1.8zvh i could always rebuild that and get the proper management.fucknose lol myt just get my head pressure tested and rebuild the bottom end and take it from there if i do that then ill take it to AVA for a set up
stage4 2wd cosworth
ye i no stevie hes worked on all my cars, put the camms and stuff in my vts.done work on my 2.1 and he rebuilt my engine in my fiesta turbo.
