Turbo charger, Super charger,,,,,, OR BOTH!!!
i think she uses this board (focus bird)???
http://www.ffoc.co.uk/forum/viewtopic.php?t=53920
only 200bhp tho
only 200bhp tho
for memory its only a 1.8...
200bhp isnt that bad...but its a bit of a weird thing to do if you ask me.. when there would be more power available by either going for a bigger S/C or just using the turbo!
zetec head is restrictive in std form is it not ?
it does seem like a lot of money has been spent for not a lot of gain
the sort of thing lewis would do just to say ive got a supercharger and a tbo
nice car tho
nice car tho
oi!
my car had a lot of gain over standard! & i spent fook all on the engine itself!
Your shit box ready for the weekend!? u got directions yet!? what time we goin!? i am goin out fri night so am gunna b fooked!!
fudgey bit off topic but ive been thinking about this for a while ive got another mk5 lined up and dont know weather to go 2.0l zetec big valve head throttle boddies etc or just opt for a fiesta turbo lump, all depending on price to power gains, what sort a mods you runnin an has it been worth the money, again im looking at 200 bhp figures? cheers dude
[quote="CraigN"]zetec head is restrictive in std form is it not ?
/quote]
Nope According to a very trustworthy source the exhaust side of the head is particulary good actually
/quote]
hello mate, currently my car is a 2.0l zetec, Fse powerboost valve, piper cross viper induction, Focus ST170 4-2-1 manifold and a dastek unichip
in a few weeks time it will have modded suzuki GSXR 42mm throttle bodies, cossie injectors and SECS S8 ecu (unichip + viper will be for sale)
then when i get some more cash it will have some fast road cams, and modded head
HTH
so you not sellin up for the 3 door any more then
and it still needed a front bumper, front seats, front screen, and other stuff, and i would have needed a cheap shitter for work etc....
plus my missus said i gotta pay out on stuff for the wedding by the end of the year, rings, suit hire etc....
so couldnt afford it in the end, bit gutted but one day ill have a cossy!
hopefully tho im gonna have an interview soon, and if i get the job i get a company vehicle, so the car will have to go anyway
but it will make room for the esc cos!!!
gutted mate all in good time tho, ah the joys of marriage got all that on at the mo aswell weddin is less than 4 weeks away now!!!
did you manage to see (i think) a copy of performance ford last month all about zetec tuning its what i want to do but seems like the expensive route just dont think i want another turbo
oooooooo thought my ears were burning.
In answer to questions about internals (oo-er) yes they have been strengthened, new pistons (modified for lowered compression) and forged steel arrow H section conrods, amongst other things.
I've lost some bhp because I've put a standard head on it, cracked the ported/polished thing I got from Cylinder Head Developments, and didn't have the money to throw at another. I used to get 222bhp with just the supercharger, but only 164 lbs/ft torque.
If you read the thread on FFOC you'll see that I said it was done just to see if it was possible and how it'd work, PE weren't even sure it would work when they started the job. We knew we wouldn't get much more bhp out of it because the supercharger is restricting the turbo (turbo feeds the supercharger - if it was the other way around apparently it'd be better) and I've tried it with my Focus cos no one has done it before on a Focus
Drives lovely, you can really notice the torque. There's bound to be people saying "oooo not much power considering blah blah blah" but I couldn't care less. At the end of the day, it's my everyday car so as long as it's driveable I'm happy
Originally Posted by hooked on boost
Didnt a guy at Power Engineering have a Fiesta running turbo and s/c? I heard that was quick?
DEYTUKURJERBS
If the supercharger was big enough, it being after the turbo wouldnt be a problem at all, but the jackson charger you got is pretty small.
You sure its really restricting it tho?
I mean, piddly lil RST T3 on it cant flow that much more anyhow, what boost you running?
A .63 T34 From an EscCos with the fueling to match and i bet youl find the s/c isnt as restrictive as you think...
Correct me if I'm wrong but the jackson racing supercharger is eaton M90 yes? if so it's more than big enough. even if it's the M62 I'd say it's big enough I run a M90 on mine and that's on a 2.9 V6 trust me it's capable of supplying plenty of air. especially when you think it shifts 1.32 litres of air per revolution (88% VE).
All I will say is mine is around the 240bhp mark (with similar torque) and the torque is amazing going from 2,000 rpm up to redline, the blower offers muchos usuable power, the characteristics of the roots superchargers is very cool compared to most run of the mill turbo road cars. I'd say the car is still prolly quicker and more drivable than most other turbo setups with 20-50 bhp more, or atleast should be.
Nice car BTW, if you wanna screw more out of the supercharger you can, which usually drops ACT's down and increases VE (volumetric effieciency) so you end up running a lil more boost It's simply from a lil bit of porting and flowing of the casing. Could even do it DIY if you're inclined that way
Rob
Rob
Mine's only an M45 JR Supercharger, if I'd thought about doing all this to it when I put it on, I would have opted for a larger one (but size isn't everything )
Will have to check, but I think I'm running 16psi I remember being told to not "go silly" with it, cos I don't want to break it
DEYTUKURJERBS
16psi thru a piddly RST T3 explains the power level then.
The M45 isnt the restriction, its just the sorta power 16psi on a RST T3 gives, if it could take it then youd see a lot more with a good sized turbo if you wanted it.
Cool car by the way
Cool car by the way
I know, but it's the money side of things - just skint at the mo.
I'd love to do it properly with a bigger turbo & bigger supercharger....maybe I will one day
JK12
33
26-04-2021 12:09 PM
