Mini's
The better half really wants a mini as her dad had one before he passed away when she was younger. Anyhow im going to get her one for her birthday in April but wondered if any one could answer a couple of quick questions.
Im looking to spend 3k plus another 1K so she can have the deep dish style mini alloys and a few other little mods. Is that a reasonable budget or will it bag me a rot box? Im 6" 2 will I have any problems driving the thing? Can anyone recommend a good website/owners club that isnt full of purists who are way to far up there own arses to offer and good advice? Thanks |
I am just over 6'3 and I had difficulty driving one, however you can get seat extenders which move the drivers seat backwards for the taller person!
I would love to have one now, need to learn to weld first tho :cry: |
I'm happy to help :DD:
Seats can be moved back on brackets - what sort of year/spec are you after? Alex |
Sounds like a sensible budget to me.
To be honest though, they drive a lot nicer on the 12" diameter narrower wheels than they do on the "sportspack" or any aftermarket wide 13" wheels. But that isnt an issue if the reason for the wheels is it looks good rather than it drives good, which without being too sexist, is what most girls into minis want anyway, lol |
Originally Posted by AlexF
(Post 3907800)
Seats can be moved back on brackets - what sort of year/spec are you after? Alex Well I have had a quick look through Mini world mag and have been looking at modles registered in or around 93-95. Seems I can get a nice looking one on my budget (3K) and still have around 1K to spend on the mods she wants. Does that sound reasonable? |
Originally Posted by Chip
(Post 3907807)
To be honest though, they drive a lot nicer on the 12" diameter narrower wheels than they do on the "sportspack" or any aftermarket wide 13" wheels. But that isnt an issue if the reason for the wheels is it looks good rather than it drives good, which without being too sexist, is what most girls into minis want anyway, lol LOL yeah dont I know it. She wants black deep dish alloys called trax or somthing similar and she has also seen a stage 3 conversion (£800) which according to her will give 100-110 BHP. |
She's wrong on the stage 3 conversion thing with the power figures quoted, it costs a lot more than 800 quid including labour to get a mini up to a genuine 100bhp+
90bhp is pretty easily got though :D |
don't need to spend 3k unless you want a more recent one an with mini's the age does not necarsarily reflect condition.
mine's an 84 BRG with a new 1380 engine / fully rebuilt box + complete rebuild of entire suspension / brakes / body etc. cooper s brakes and entirely rust free. paid £2.2k 2 years ago but never get the time to use it. probably get more use if it was red instead of green |
Originally Posted by PGT
(Post 3907833)
chasing rust on a mini is like painting the forth bridge!
Hopefully i can get a good one and then do some work to help prevent it in futre like waxoil the underside etc
Personally I would go for a mini RSP, I believe that of the modern minis these are the best available, but I would want to keep it visually standard if I did so.
Failing that, any pre 94 (thats when they started getting bloated with catalytic convertor airbag etc) cooper is a good bet. As per above, buy it on condition, not anything else, the single most important thing is the bodyshell, minis rust a LOT, some were getting rust repairs done under their 3 year warranty, even stuff like new sills! |
(Post 3907872)
(Post 3907888)
when they were built they moved the shells across the road to the paint shop!
What about the engine what should I look for there
All good advice above, most of the SPI (1994 - 1997ish) Coopers don't have the airbags etc, mine is a 95 and doesn't. They all rot like buggery sadly and everywhere. Mine looked mint when bought a year ago, has now got rot showing on both front wings and a panels, and a small hole underneath near rear subframe, also needs one sill doing! Defo make sure you get the mintest shell you can find. I would be inclined to get a cooper, if you want the big wheels then I would go for a spotspack or one with the arches done, the wheels look silly without the arches tbh.
They are not cheap cars to own and you will be forever working on them, but really good fun when they are working! www.theminiforum.co.uk is a good place for info |
Originally Posted by Kamike
(Post 3907898)
The wide wheel cars tend to much the diff pin, but its not very easy to check that, as its an engine out job to look at it properly! |
(Post 3907898)
Engines are fairly good really, but oil leak from underneath is likely to be the oil seal on the gearlinkage, you can get a fix kit for it which is easy to fit. On the SPIs and the MPIs ecu and relay pack issues are fairly common, the relay packs are £100 new. The fuseboxes go all the time too, but they are only about £15, you can upgrade to blade fuses rather than the crap glass ones. Make sure any car you look at has the watersheild fitted, it comes off the rockercover and covers the dizzy, leads and plugs etc. |
Originally Posted by Nomaderst
(Post 3907914)
SPI & MPI what does that mean sorry?
Single Point Injection
Multi Point Injection TBH although on every other car in the world MPi is a big advantage, due to the 5 port cylinder head design on a mini, the same isnt really true. The SPi is actually a very good setup IMHO for these cars. |
TBH when she said she wanted a mini i was dreading getting one but the more I look at them and read some of the feature cars in the magazine I got the more excited im getting about getting one lol. Might have to be a joint birthday present now as she was born two days after me.
Me and my mate have just had to search high and low for an old austin mini, there like hens teeth to find, well in his price range anyway!. He wanted an old 1 as he's at college and aparently there all the rage now! We ended up getting 1 that had just had a full restoration but had been stolen and crashed at the bottom of the blokes street :cry: :cry: :cry:. We give £1500 but we've spent another £300/£400 replacing panels and lights. His dad is 6' 6" and has drove it, although he said it wasn't the most comfortable experience of his life! he is 6' 2" and can drive it.
Good budget - but not for 100bhp!
For that money get a SPi and fit a stage 1 kit - anything else is lots of time and effort (well for most people anyway as I am getting lots of tuning work for these atm!) 13" can be made to handle well - but you will be stuck with heavy steering. Alex |
proper mini's have 10 inch wheels
(Post 3907807)
Originally Posted by XRdodgybird
(Post 3908219)
12"....... nah.... for the ultimate in mini driving experiences... it needs to be on 10s!!!! :top:
Ive had 10/12/13/14 inch wheels on various minis I have owned, and its only when going to 13 that you really notice a big difference. The key thing with the 12" is to be on 165 wide tyres and to keep the profile to a 60 at most Offset of course is also key! |
10s do not handle best LOL
13s offer more mechanical grip BUT you need to change the suspension geometry to work them!!! Alex |
(Post 3908320)
(Post 3908364)
The height of the sidewalls on 10s are not that much bigger than on 13s....
Youllget bitten by the Bug mate im telling you
i still miss the noise the doors make when they shut the way that you can drive them without using the brakes and that fact you can make them into anythin you want |
(Post 3908516)
165 * .70 = 117.6 = increase of 30.1 mm = 34% incrase in sidewall |
good budget you should be able to get her a goodun
me mates got a yellow one to tune for when he can drive and it is amazing :grin:
no brakes and full throttle is the only way to drive them :king: |
Sounds like a good budget but it won't buy a fire breather. Like was said above purchase on bodywork condition alone! Check for rust in all the usual places including the rear valance corners, roof gutters and where the scuttle panel and wings meet, also the front grill surround...basically everywhere.
Ignore all the talk of 10" wheels, they are great but require either original 7" cooper or 7 1/2" Cooper 'S' discs - and they are very expensiveand are not a straight fit as you also will need different drive shafts and outputs. For an everyday car thats nice go for a good bodied 12" or 13" wheel (with discs- usually 8" IIRC?) running basic car, you can always tune it later! The parts are very cheap for minis but the actual cars are quite expensive. The 12" will give you lighter steering and the 13" will be a bit heavier, in a mini its not all about grip, but balance....(If it has aftermarket 13" wheels, make sure the offset is right or steering can be very heavy!) The seats and interior are easy to modify to accomodate a different height of driver, and you will be amazed how comfortable they are. Basically they are great fun and a fantastic car to hone basic driving skills in, 30MPH never felt so fast! :) Above all have fun with it :) Good Luck! :) |
Brakes wise you do not want 7" brakes they are lethal and worse than drums! 7.5" (cooper S) brakes are ok. But you can get 10" that clear 8.4" disks :)
Its all easy to sort out as the same basic car was in production from 1959 till 2001!!! Alex |
Im SO going to put one of my minis back on the road, im properly missing having one to drive about in after this thread!
(Post 3910227)
If im going to give you one, can I see some pictures of what you look like?
| All times are GMT. The time now is 11:43 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
