044 fuel pump
044 fuel pump
can anyone help i need to get new fuel pump i think 044 i will be running stage 3 on rwd saff wheres the best place to get one from and how much do you think it will set me back ????
Ł100 inc fitting to standard pipe,, thats an uprated 044( which comes standard as 7 bar) these are bosch motorsport ten bar Ł435 plus vat from tweeks (ks169)
A std pump(941) is fine at stage three, the so called group a pump(044) is obviously better flowing but the difference is minimal, they don't do any particular BAR as std, they don't work like that, as that depends on the voltage, for example the std pump[ can achieve 9 bar if needed to, the 044 pump locks out at 11.2 bar and 18 amps power consumption.
Matt Lewis would be my choice 01922 692424, don't forget a new fuel filter as well.
whos running a Motorsport pump (261 205 413) can i get away with running a single one of these on my car? 8 greens on a RS500 set up , T4 etc ? thanks in advance
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
