Headlight bulbs
Ive just ordered some Philips Exteme.
Meant to be good, so thought i would give them a go.
http://cgi.ebay.co.uk/PHILIPS-X-TREME-POWER-H4-EXTREME-XTREME-XENON-BULBS_W0QQitemZ380099355839QQcmdZViewItemQQptZUK_C arsParts_Vehicles_CarParts_SM?hash=item38009935583 9&_trksid=p3286.c0.m14&_trkparms=72%3A1301|66%3A2| 65%3A12|39%3A1|240%3A1318
I have philips x treme in one car and the latest osram nightbreaker in another car.
There is very little in it, but the x treme is better, the light is very HID like on dip in colour, main beam is more yellowy like a normal bulb.
On the astra that uses the x treme I have wired the dip so it is on all the time the lights are switched on even on main beam, makes a BIG difference, and doesn't kill the bulbs.
I do a lot of night driving in the countryside, but have just bought a HID kit from HID DIRECT, a H4-4 35W BI Xenon, better than the H4-3, was £81.49 delivered the next day.
Prior to having nightbreaker and x treme I had 130/90 watt bulbs(with relays), and the x treme/nightbreaker are around 2-3 times the brightness despite being lower wattage.
The Halfords Super Brilliance ones are pretty good. Normally got some sort of BOGOF going as well.
HID ones fitted as aftermarket can be illegal remember:
http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
It's a debateable area at best, bit like VOSA stating to fail certain cars with bulbs that are e marked because the tester thinks they look too blue, even though they are e marked as been through a light machine to measure colour!!
I know, just the luck of the draw with tester, my one says so long as it has a correct beam pattern and appears a normal colour he doesn't care if it is a candle inside so long as it works!!
Why do you want dip on with main, no point seeing what main beam lights up a split second previous.
Like having fogs on for better vision, gives you 0.1 seconds to react to a hazard
Hi,
Yes it is a piece of cake, all you have to do is have the lights relayed first, then simply take a wire from the output of the main light switch and link this to the output of the stalk dip wire, so dip is always fed, selecting main beam via the stalk simply turns the main on or off.
To see the effect simply pull back on the dip/main stalk when driving at night, do this only for a few seconds to see if you will like it, some don't, but this will show what the simple mod looks like.
It is LEGAL and MOT passable too.
I do it as round here in Norfolkshire, there are rabbits deer etc running all over the place at night, so every little helps.
I like the way the foreground stays illuminated even on main beam, instead of losing the immediate lit up area in front of the car.
Not for everyone but I like it, I never thought you were having a dig!!, as I say some like it some don't, just mentioned it as it is a freebie to do.
I first did this on my mk4 escort, as the lights were unbelievably bad, even with 160/100 watt bulbs in them, fitted 4 extra lights on in the end two cibie main/dip units, two main beam units all between the headlights!!
just finding my feet
the HID are not legal, fucks me off being blinded by some idiot on the motorway when there fitted !!!!
they scatter the light too much due to the reflectors in the headlamps
later cars will be fine but early motors with glass headlamps aint !
As ginge says, aftermarket hid kits are illegal whichever way you look at it. Someone from my local area was pulled at a vosa roadside check and was bumfucked for his.
Its not just glass reflectors, they dont work properly in modern day headlamps either, my car failed its mot with them fitted. They don't give the right beam output as the reflectors just cant handle the intensity of them. I had a hid kit on my old car, I got fucked off with being flashed all the time, and they are shit compared to proper hids like i have on my car now!
You're lucky that the ST170 did come with an optional HiD pack so you have properly designed HiD lamp assemblies you can put in to replace the halogen ones.
That's the only way to get them properly fitted, much like jags etc that had that option. It'd be interesting to see the direct difference between a Halogen ST170 and a HiD ST170 beam pattern / range..
I think the beam pattern is pretty much the same as an ordinary focus with halogen bulbs. On my old focus i had halogen st170 headlamps on it, and the beam was about the same as my xenons i have now. When i fitted the hid kit to my old car though, the beam pattern was non existant!
I don't think my xenons beam goes any further but it is noticeably wider than a halogen bulb, and of course, a lot more like daylight!
Steve Escos
01-10-2015 06:57 AM
