Zetec bottom ends ?
XR3i ALEX
Zetec bottom ends ?
HI ALL,
Just doing a zvh at the moment,Goin to the scrappy next week and i am going to get a bottom end. But whitch one is the best,2.0l or 1.8 and whats the diffrence,also what clutch and flywheel do you use and what they like on fuel ?
2.0 is best as its bigger to start with, will require different pistons like 2ltr xe ones as they sit lower in the bore which lowers your compression, as for flywheel if yout using mfi then standard rst one with uprated clutch will be ok you just have to drill the flywheel holes out to 11mm iirc as the bolts are bigger, hope this helps.
Whilst your at the scrappy grab a 1.8 escort fiesta zetec sump and oil pick up pipe as you will need this if fitting into a erst.
Colossal Pervert
On another note i have a few mates that run std blacktop pistons @ 18psi and never gone wrong.
Colossal Pervert
Apparently (I say that because Im yet to try myself) the XE pistons in a 2.0 zetec block with a CVH head gives a nice and low CR, with a Zetec head, its around 8.3:1.
And the 2.0 Zetec block has piston cooling jets
grishenko45
09-09-2015 12:58 PM
