Focus Mk1 Central locking problem
Old Dec 6, 2008 | 07:00 PM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Default Focus Mk1 Central locking problem
Just after a bit of guidance regarding the wifes Focus 5dr Ghia. (99 T reg)
First thing in a morning when you unlock the car from the remote key, it unlocks and then starts to cycle (ie Lock/unlock) about 10 times.
Once the cars warmed up and been driven, it locks and unlocks fine.
Could it be one of the door motors playing up? Or is there a central locking module somewhere which plays up?
Doing her head in, and therefore she's doing mine in! LOL
Any ideas before i start ripping door panels off?
Old Dec 6, 2008 | 07:07 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
i reckon one of the doors isnt unlocking, thus making the rest lock again...
take a look and see if any arnt unlocking
Old Dec 6, 2008 | 07:17 PM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Thats the mad thing, they all unlock, then lock straight away again!
You have to be like quick draw mcgwar to get a door open
Old Dec 6, 2008 | 07:18 PM
JTECH James
Passion for Fords!
its possible there is a broken wire on one of the shut looms going to ground as they are often earth controlled, worth a look...
Old Dec 6, 2008 | 07:28 PM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
OK, looks like ive gotta start pulling bits and pieces off it!
Looking on the net the Mk1 focus has loads of central locking problems..
Foookin cars!
Old Dec 6, 2008 | 07:33 PM
JTECH James
Passion for Fords!
did you know, if you press the unlock button once it should unlock the drivers door only,
press it twice to unlock all doors...
my mre has a mk1 aswell
Old Dec 6, 2008 | 07:39 PM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Yeah we know all about the two stage unlocking stuff, we have had the car 7 years, and its only just started giving us a few problems...
Some posts ive read is that the main central locking fuse contracts when its cold and causes erratic problems like ours? Dunno if theres any truth in that 'cos it only plays up when its really cold???
Also the fuel gauge has suddenly gone to tits as well, its all over the shop, sometimes reading full, when nearly empty... etc etc
Would that be the sender unit as i suspect?
Old Dec 6, 2008 | 07:43 PM
JTECH James
Passion for Fords!
could be the connection on the sender again worth a look,
my mrs has a weird issue with her locking, when you unlock the doors and drive off it fine, then all of a sudden it will lock itself after about 5 mins when its warmed up...only does it once first thing in the morning...
weird hey! maybe il have a look at the fuse
Old Dec 6, 2008 | 08:22 PM
focusv8's Avatar
focusv8
Check the earth for the locking module.
Module is behind drivers footwell r/hand side "a" pillar panel, mounted in front of the ECU, earth is on the inner sill just rear of the module, there are several earth points in that area.
Fuse is in the glovebox fuse unit F.63, BEHIND, where the plugs go in, remove 2 screws to drop out fuse holders or stand on your head, break your wrist and put it up behind the fuse unit with a mirror and torch.
Old Dec 6, 2008 | 09:51 PM
Chris69's Avatar
Chris69
does it do it with one press for just the drivers or when you press it twice for the whole car?
my mk1 ghia use to do it cus the passenger door module was broken so it would get confused and try and re-lock itself like mentioned above.
if its doing it with only one press then i'd guess something up with the drivers module seeing as thats all it deals with when you only press it once.
Old Dec 6, 2008 | 10:12 PM
RichieST's Avatar
RichieST
Get the wd40 out, and lube up all the locks, hinges and cables ect. You will need to take the door panels off tho.
Just a sticky motor, my old focus used to do exactly the same!
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
