car cranks but it wont fire
escos not been started in 3 months, new battery, new fluids, new filter and petrol , plugs etc, plugs are sparking. but getting soaked but it wont catch , list of things I need t work through ? ta
neo - no alarm on it - fuel pump deffo working as changed the fuel filter and have dried the spark plugs enough times tonight. immobilizer i thinks ok - red and yellow light on when you turn key and then they both go out??? what is the correct proceedure with the escoc immob ?
Shizzle My Nizzle
Never had any issues with mine, and it was standard imob.
Really difficult to say, prob something really simple.
have you rechecked all wires are where they should be, and double checket the new ht leads are all secure and fitted in the right order.
Received 1,044 Likes
Is your escort the big turbo model.I would check the 3 black electrical plugs near your pas bottle.Also check your phase sensor inside the dizzy cap under the creamish colour cover.Your water temp sensor might be faulty too.It might be overfueling your engine that much that its causing it not to start.
plugs are brand new, will have to go thru everything I suppose
any more suggestions would be appreciated though ....
Location: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
Stu @ M Developments
41
21-08-2015 06:47 AM
st220kyle
16
14-08-2015 06:13 AM
CabrioTurbo
01-08-2015 11:04 AM
lockie
31-07-2015 10:03 PM
