e85 fuel
Old Oct 31, 2008 | 08:57 AM
saph4be's Avatar
saph4be
Default e85 fuel
keep hearing off this lately what is it and what's it all about ie pros and cons what mods are needed to use it
Old Oct 31, 2008 | 09:03 AM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
E85 is a etanol bases gasoline with the sweedes are using A LOT now.
Good thing is the det point is a lot longer out, so you can get more agressive ignition = more bhp but negative side is the fueling is upped about 30-40% and it´s hard to find the det point because the area where it det´s is big, not like "normal" fuel.
Short description, hope you understand.
Old Oct 31, 2008 | 09:22 AM
saph4be's Avatar
saph4be
Good thing is the det point is a lot longer out, so you can get more agressive ignition = more bhp but negative side is the fueling is upped about 30-40% and it´s hard to find the det point because the area where it det´s it´s big, not like "normal" fuel.
yep understand is it just a question or remapping to run this fuel then or are other mods needed?
Old Oct 31, 2008 | 09:25 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
The other negative side is of course the massive cylinder pressures created by adding more and more ignition due to the higher det resistance the fuel gives
Old Oct 31, 2008 | 09:30 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You'll need more headroom in your injectors and the rest of your fuel system.
Also, I don't think you can mix it, so if you want to run it you need to drain the system and change over to it and as its not that abundantly available, thats not very easy.
Old Oct 31, 2008 | 09:32 AM
cossiemanden
No other mods needed, other then to check if your injectors doesen´t have a problem with etanol bases gasoline, some injectors do.
Rich: yes, you are right, but hopefully people check that on the dyno
Old Oct 31, 2008 | 09:33 AM
saph4be's Avatar
saph4be
thanks for all the info guys i can stop wondering now
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
