what aftermarket management do people run on their cossies?
Old 23-10-2008, 02:46 PM
  #81
Chip
*** Sierra RS Custard ***
Chip's Avatar
Originally Posted by Azrael
And you would end up in fail safe mode anyway because of some obscure fail safe control in the OEM ECU that won't ever activate on right car and will on the one you installed it in.....
Well it would be down to the mapper to eliminate that problem, but yes its just one of many difficulties that you would face, and all for no real gain anyway.
Its just a silly idea really.
  #82
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Originally Posted by CossieRich
Mike,
it was amusing though
To you - and don't even THINK about doing it again or I'll have to add you
Old 23-10-2008, 02:51 PM
  #83
Chip
Chip's Avatar
Ive heard the saying "the truth hurts" before, but I never realised that in your case getting called a hypocrit and having it pointed out you were misleading your customers would have you so upset for so long just cause it was all proved to be true
Old 23-10-2008, 03:00 PM
  #84
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
Stu,
Is there no OEM ECU that you have sufficiently hacked that is common and cheap enough to use as an aftermarket one for muchos cheapness that has all the features most people want, or is this the reason sticking with the Webber IAW?
I know someone that started to do this the the EEC ECUs, but he's too lazy to finish it (same as his engine monitors) .
No. Why? Simple. Most modern OE systems based on systems such as the TRICORE system cant be live mapped, negating their use for engines other than those they were designed for originally sadly. It is virtually impossible to write an accurate calibration for a totally different engine to the one you have a base file for and get all TEN THOUSAND calibrations correct. That needs emulation.
We are in fact spending a great deal of time and money on one specific form of ECU at the moment, in fact, your mate Guido is helping me out with some translation from German to English this weekend. We should know all we need to know about that system by Xmas this year i expect and will open up a nice Niche in the aftermarket tuning arena as we did with Weber all those years ago. We all need a sideline to detract fro the drudgery of daily business don't we?
Thats the good news... for me.
The bad news is, its an EDC. So all you have to do now is guess what EDC means to figure out why its BAD news.
Old 23-10-2008, 03:05 PM
  #85
lead_foot
is awesome
lead_foot's Avatar
Err...Education Development Center, Electric Daisy Carnival, Environmental Defense Center, EROS Data Center (US geological Survey), Evans Data Corp, Export Development Canada, Am I close?
Old 23-10-2008, 03:09 PM
  #86
Chip
Chip's Avatar
Bad news = The D stands for diesel?
(Electronic Diesel Control)
Old 23-10-2008, 03:11 PM
  #87
lead_foot
is awesome
lead_foot's Avatar
extradite diesels completely?
Old 23-10-2008, 03:19 PM
  #88
Administrator
You sir, have just won a Carrot.
Old 23-10-2008, 03:20 PM
  #89
AlexF
AlexF's Avatar
Originally Posted by Stu @ M Developments
Missed this question, Sorry.
Totally different system actually. They use the Siemens MSS 65VDO 5WK9 range. Google it mate, see if you can dig anything up. Serious systems.
Hmmmm iconic knock control....
  #90
Chip
Chip's Avatar
Awesome, if its true what all the old wives tales say, it will help counteract the negative effects of one of my hobbies.
Old 23-10-2008, 03:21 PM
  #91
Administrator
Genuinely funny, and a well versed hint as to why i have a large stock of carrots.
Old 23-10-2008, 03:24 PM
  #92
AlexF
AlexF's Avatar
What helps you see in the dark?
Old 23-10-2008, 03:25 PM
  #93
Chip
Chip's Avatar
Yes, where as worsened eyesight from masturbating of course hinders you seeing in the dark (vision in low light conditions will of course be even more adversely effected than in good light conditions as a result of a deterioation in sight)
Old 23-10-2008, 05:10 PM
  #94
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Originally Posted by Vic
what's Autronics???
www.autronics.com - you guys must have some serious aircraft!
So glad you showed that, nothing annoys me more being told im on AutronicS not Autronic, some of us knew about the other company..
Old 23-10-2008, 05:29 PM
  #95
stu21t
stu21t's Avatar
ok can any1 tell me If a cheaper ecu- dta or omex, is better than a L8?
They come with more toys- closed loop, launch control, ALS, dizzyless......
But are they as good/better than the STD ford management?
I have level 8 ATM but want all the toys and if I add them to my current ecu it will end up dearer than buying said new ecus.
Old 23-10-2008, 07:13 PM
  #96
Administrator
To run what spec?
Old 23-10-2008, 07:37 PM
  #97
Paul_RS
Paul_RS's Avatar
I don't think its worth changing an L8 for aftermarket unless you have a mad spec?
Stus LC/ALS/Wasted spark are all easily enough fitted to the L8, plus you need no mapping, just a fuelling check to make sure everything is ok. If i can fit it - anyone can
I'm fitting a DTA S60 into my mates car at the minute and to be honest, while is not hard its a ballache to make everything look pretty, working out what way to route wires etcetc. the it needs mapped.
Fair enough the s60 has a lot of extras on it, but not enough to warrant changing to it if you have anything less than a spec Stu can do an off the shelf chip for...
Old 23-10-2008, 08:29 PM
  #98
Chip
Chip's Avatar
Better at what?
It will do more things, but not as well.
Old 23-10-2008, 08:33 PM
  #99
Rick
Rick's Avatar
I'd love a play with T6. Omex, Emrald, Gotech are the ones ive played with and are pretty poor for a road car imo. I've got MS on my s2 purely as i like the development aspect. It's running a totally std 1600 on Greys at 15.5:1 idle. There are something like 8 maps and tons of switches for the transient fuelling at the moment which means 100+ hours mapping really.
Rick.
Old 23-10-2008, 08:35 PM
  #100
AlexF
AlexF's Avatar
That MS still working well Rick?
Old 23-10-2008, 08:37 PM
  #101
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
L8 or ...
Old 23-10-2008, 08:41 PM
  #102
Jay,
Sponsor
Jay,'s Avatar
Originally Posted by martin-reyland
L8 or ...
ur getting into this tuning martin int ya lol
Old 23-10-2008, 08:43 PM
  #103
Rick
Rick's Avatar
Alex,
yea sure is - not one ounce of trouble. Few mods like proper peak and hold low impedance drivers plus digital ignition drivers, but they're really only for experimentation purposes
Old 23-10-2008, 11:12 PM
  #104
stu21t
stu21t's Avatar
im not running big spec,
std comp
greys (atm)
bd 10 / 14
long stud
t34
headwork
nothing special.
but i want toys, lol
if i can add launch controll and wasted spark to the l8 and it is as good/better than dta/omex then thats what ill do. but wasnt sure what would be better.
guess thats next for my car then. lol
Old 23-10-2008, 11:14 PM
  #105
Chip
Chip's Avatar
If you dont want to map it yourself, L8 with all stu's toys is a good option.
DTA and Omex are ok, but not "finished" by comparison.
Old 24-10-2008, 08:55 PM
  #106
Administrator
std comp
greys (atm)
bd 10 / 14
long stud
t34
headwork
nothing special.
For Łs spent, you wont beat the refinement of L8 then mate. No way.
Old 24-10-2008, 09:41 PM
  #107
TimC
TimC's Avatar
Awesome read so far guys. Just wish I understood more of it!
Anybody up for teaching me a bit please?
Old 24-10-2008, 09:53 PM
  #108
AlexF
AlexF's Avatar
What do you want to know?
Old 24-10-2008, 10:50 PM
  #109
TimC
TimC's Avatar
Understanding what transient fueling is and why its so important on a road car to start if thats ok Alex?
Old 24-10-2008, 11:11 PM
  #110
cossiemanden
DANISH cosworth abuser
cossiemanden's Avatar
Martin : you have a pm
Billy_RS
15
05-09-2015 12:04 PM
CrOwSoN15
18
22-08-2015 10:24 PM
turbobill
09-08-2015 05:21 PM
Cameron
14
09-08-2015 06:28 AM
Quick Reply: what aftermarket management do people run on their cossies?
