Cossie stroker kits?
2.4 is the norm
millington race engines have been known to do a 2.6 conversion on a yb how safe or reliable is anyone's guess.
Regards Doug.
Regards Doug.
ZETEC TURBO
[QUOTE=3i_gaz;3673425]chorley street geoff had a 2,4 stroker in that cossied tranny mate, migth be worth a chat with him hes a sound lad[/QUOTE
As he sold the tranny?
ZETEC TURBO
Am tryin to find out as much info as my boss is building a mk2 with a Cossie and wants a stroker thanks for everyones help!! What sort of price are they martin?
C.R.E.A.M.
Collins has always done the 2.3 conversions ,a company called Suhe in Germany did 2.5's on escort cosworths and they were tuved and a ford dealer too, heres a spec of a Suhe Turbo Technic escort cos
Escort Cosworth Motor 2,5 L, T04 Lader, Steuergerät - 515PS/699,7NM
Verkaufe einen 2,5l Motor von Fa. Suhe, kpl. modifiziert von Fa. Gabat mit starken Stehbolzen,
starker Kopfdichtung, scharfen Nockenwellen und einstellbaren Nockenwellenrädern alles Fa. Gabat,
mit Krümmer und kompletter Ansaugbrücke incl. Düsen + T04 Racing-Lader von Fa. Gabat incl.
Ladeluftleitung zum RS500 LLK + Steuergerät mit entsprechender Programmierung von Fa. Gabat.
Komplett einbau- und fahrfertig. Alles techn 1a, ohne Mängel und mit Belegen.
Leistungsbericht mit 515PS und 699,7 NM vorhanden.
Nur komplett zu verkaufen.
Evtl. mit RS500 LLK und Charge-LLK(Wasser-LLK).
Bitte nur ernstgemeinte Anfragen
[QUOTE=rst-g;3673445]not too sure mate havent spoke to him in a good few weeks, hes been busy with his new house and the new connect. so hopefully might still have it tucked away
C.R.E.A.M.
escort cosworth 2.5 suhe video :-
check clumsy fritz at the end
also note the big hoops the German Escort has
http://www.myvideo.de/watch/3556414/...uhe_Motorsport
Caraholic
I would avoid the old 2.4 engines like the plague, as they use SHORTER rods than standard, so combined with a big stroker crank, the rod angle goes to rat shit and they get horribly vibrationary above 5500rpm (ideal for towing caravans though ).
The best stroker conversion is obviously one that uses a rod angle BETTER than standard (or no worse at the very least). The only way to do these with any big success is to use a taller block. You then have the best of both worlds - improved rod angle and larger capacity.
My own engine is a half way house, it has fractionally better rod angle than standard and with a bigger bore (93mm, which is the limit on a standard linered block IMO before wall thickness becomes an issue), and with a 82mm crank and custom rods (8mm longer than standard) and custom pistons (shorter compression height), it achieves 2225cc.
Caraholic
The only real issue I had was the first time we tried to use a 93mm bore on a standard unlinered (albeit early thick wall) block.
This was cured with liners.
We then had the exact same issue as Martin with a certain supplier's crank, where the nose fell off the crank .
Since these issues have been resolved, the car has been bullet proof .
Sorry to go back a bit, (i think someone else asked this question), but why dont these 2.3 and 2.4 strokers get used as much on cossies, when it seems they do the world of wonders for the evos boys
Is this down to money sides of things or is jus because there is no real need to go that extra capcity, and to just be done with a longer throw on the rods ??
Cake lover!
1.8 is very good, whats your capacity, i guess you run a different bore size? (sorry i'm not really into the cosworth scene just comparing to other car's), how many RPM's are you doing?
I'm currently running 1.5 rod ratio on a honda, and revving to 7800 rpm's. (standard rod ratio, limiter is 7200 standard on this engine)
