Cossie stroker kits?
#46
Power Engineering ( as mentioned before ) used to do the 2400 kit. I have an article from the old "Top Car" mag about Mark Lovell driving a 2wd and 4x4 version back across France in them. Promised to scan it in ages ago for user Evo200 but I forgot ......
Will try and do it in next couple of days
#47
Mark
#49
#51
1st to 200 without NOS
#58
is awesome
Might be intresting reading:
http://www.stahlheaders.com/Lit_Rod%20Length.htm
http://www.chevytech.net/2c27o1.html
#59
What would a Holbay YB Stroker crank be worth these days?? I have a full YB 2.4 Holbay stroker engine in my shed but cant find one of the rods. I was thinking of either building it back up or just selling off the crank and keeping the rest as spares.
Worth doing or no??
Worth doing or no??
#60
*** Sierra RS Custard ***
Longer and shorter rod ratio each have benefits depending on the rpm you are running and the compression of the engine, and the boost you are running.
A smaller rod ratio can be particuarly good for midrange torque for example.
A rod ratio like martin has for example, I personally wouldnt actually want on a road car with big boost, but on a N/A 10K screamer, it would be fantastic.
All about what characteristics you want from your car.
#61
Just wonder, Harveys 1.78 rod angle, would that be standard bore & crank, longer rods and shorter pistons??
How would Harvey's engine run compared to another engine with the same power but standard rod angle, i.e, what are the advantages?
#62
B1mbo
The advantage of running a better rod angle is to allow the engine to rev more freely. The piston isn't driven into the side of the bore so much.
That engine was a standard stroke standard size bore engine with the longest rod and shortest piston we could get at the time.
I beleive now it's possible to go 141mm rod in a standard deck height block giving a 1.83 but we don't use this.
Ps that engine pulled 9k rpm on the dyno and regularly 8500s in the car!
#63
Would that combo give a slightly bigger capacity with the smaller piston size?
I was wondering would you lose torque as a result of the increase in rod size? What were the power figures of the car, if you don't mind me asking, always interested in learning
8500s, bet it went like a rocket, what car was it in and how quick was it?
#64
B1mbo
It was in a group a escort cosworth
It done 0-60 in 2.63 on low boost and 100 in 5.5 on high boost around 600bhp the new engine would have been high fours to 100
Yes a shorter rod does make more torque but it's not a night and day difference IMO
Capacity is original just under 2000 cc and yes it is down on torque in comparrison to stroker engines.
Power figs 613bhp at 31psi and 465lbft useable power was 4000-8500
#65
#67
Reason for the questions is I'm looking to build or have an engine built for my escort cosworth, you speak to different tuners and get told so many different things with regards to compression ratios etc, seems some get stuck in there ways and others push the boundaries and try new things, some people still are using low comp where others are higher, the people using low say the higher cant be run and will be issues with reliability etc you just feel like lol. Ive been out of the scene for a while and when I had my previous turbo's everything was low compression, since then things have come a very long way, especially with cosy tuning.
Even if I have the engine built I still like to know and understand how it works and what effects it will have on the engine and the way the car drives and runs etc,
Thanks for the replies
#68
That is proper quick, what compression ratio was the car running and was it on race or pump fuel? Also I guess those timings had a lot to do with the car set up, transmission & suspension
#69
I've been advised by some people to run 7.6/7.7 and say anything more would be unsafe at higher boost
I know compression ratios is an age old discussion, but IMO year on year boundaries are pushed and more power and reliability achievable from the yb engine, I can remember a time when 380 bhp was seen as mega and yet now you can have a reliable 500 bhp car
#74
Happily retired
8.5 compression ratio -2.8 bar of Boost & 8.8k limit on revs. 838bhp/666ft-lb. This suggests your advice is incorrect as my MAD engine seems to work rather well. The new engine will be better as 5 more years of development will go into it. However this level of engine is very expensive & its always a case of How fast can you afford to go.
#75
But what would the rest of the engine spec be? Would you be running lower revs and boost than Harvey's engine
Mark
#77
All other things being kept the same and if you're already at the point of detonation at crucial parts of the rev range then I would lower c/r when using a higher rod ratio. Unfortunately it's no use saying that low comp is shit or high comp is shit as it's the complete engine build that matters, people have had good results with both. Where people have bad results is when they listen to 5 different people's advise and then build it themselves. Choose 1 tuner/engine builder/whatever they're being called this week and put your trust in their advise and/or service
#78
B1mbo
Compression ratio was no lower that 8.0:1..
We personally range from 7.7-11.5:cr it completely depends on what the engine is for and spec.
Big engines we don't go below standard cr, as mark says turbos manifolds and cams make a huge difference on what cr you can run it's all a juggling game at the end of the day, it's easy to just put an engine together and it work but to get a really well working complete package takes development. Hence the use of a bench dyno IMO is essential.
My own engine spent a week on the dyno playing with cams and I could vary torque from 450 to 490lbft of torque just with timing
I settled at 470lbft and 552bhp as 2wd I didn't want too aggresive and wanted a wide power band
I was keeping it very basic as I didn't want to make an article about it. But as its very interesting understanding piston speeds and dwell etc and their effects go ahead
#79
B1mbo
#80
B1mbo
