Is this engine kaput?
Guest
Posts: n/a
The knock is know as diesel knock. Black smoke can be a timing issue but can also be caused by a blocked air filter, blocked fuel filter can also cause fuel timing issues. When was it last serviced?
Take it the glow plug light isn't coming on?
Guest
Posts: n/a
Ok gone out for a drive, no black smoke at all. Sounds really bad even when warm, but I noticed a 'whooshing' noise, sort of like a turbo but really loud and dies off as the revs climb. Didn't notice this when revving it from stationary though.
Serviced at local garage owned by a friend, which is where it's at now.
That sounds like diesel knock to me. Not a mechanical issue.
Common problem on the injector pumps is the advance solenoid. This can be replaced without removing the pump itself. It is connected up (wiring) under the top cover of the pump (remove it, might have to cut the 2 wires IIRC) and is bolted into the pump at the very bottom by 2 bolts, then slides out. If it won't come out, the injector pump is breaking up and will need to be removed and remanufactured.
