turbo down pipe help please pics
DEYTUKURJERBS
"Heard" and "reality" are very different. Quality isnt as good, but going by ones ive played with and friends have used, I wouldnt say its 4-5 times worse like the prices would suggest, not even twice as bad.
Their Supra is the first Jap powered car in the 7s down the quarter in Europe, so their stuff cant be that shit can it
Depends how you look at it. If you are spunking aload cash on an engine why go half mesures on the turbo. personaly i wouldnt do it but each to there own.
The money you might have to spent on a custom downpipe would be better spent on a better turbo imo.
DEYTUKURJERBS
YES I KNOW I CANT SPELL
Yead i know its a bit hard when trying to get a turbo that the ford guys dont reguarly use
but jdm performance do real ones and at good prices here is the link http://www.jdmperformance.co.uk/univ...ubID=333000319 and if you really want a v band outlet without paying stupid prices get someone like lee from fusion to weld a vband onto the exhaust housing lots of honda guys do it and have no issues just use a mild steel one for safety honda-tech.com is down so search the site later on for v band in the welding and fabrication and make sure you put the dot in the archive section so you bring up old posts also check atpturbo.com as this will tell you the compressor inlet and outlet so you can get the right boose hoses
hope that helps
hope that helps
no all i need is the bit that bolts to the turbo??? so if i can fined a car that comes standard with this type of fitting i can order it in at work?
DEYTUKURJERBS
The turbo COMES with that type of fitting if that pic is to be believed! Then you cut the standard flange off your car off, and weld that one on.
Look inside the clamp in the pic, the other bit of the v-band thing is there by looks of it.
To get one yourself youd have to know what size it is too, as v-bands come in all kinds of sizes.
Not sure if any stock car comes with em tho, usually seen on larger applications, and of course modded cars.
09-10-2015 07:38 PM
andy130
02-10-2015 08:48 PM
Matt Baxter
16-09-2015 08:30 PM
track.focus'd
12-08-2015 05:53 PM
