Before I take a sledgehammer to my car.....
.... does anyone have any suggestions to removing the bottom pin on a Bendix caliper????
too dark for a pic, will get one up tomorrow, only the standard ford caliper, but tried allsorts, Plus gas, Brake cleaner, wire brush then hitting it, maybe the hammer isnt big enough?
Just for the record this is what I hate about Haynes cos they make it look so easy!? in the pic the pin just slides out!!!
is it 2 pins going through the pads? if so i use a punch and a hammer and tap them out, if tight i push the plate that retains the pads in place which springs on the pins away from them, hope this helps if these are the kind you are on about?
The pin on a single piston sliding front calliper? It has one top and bottom? It " should" just need un doing with the allen key till it is totally free then a wee tap with a long punch or screw driver and out it pops.
Daft question, but have made sure it is full loosened from the threads?
Once u only have one in (cos it sounds like u have removed the other one) u can pivot the calliper and pad cradle and work it loose?
RW
RW
no, its one pin through the bottom of the caliper, when i get it out, i can slide/rotate the caliper around and off then take the pads out.
http://www.liwebmasters.com/el%20cam...sembly_gif.jpg
is it one of the two "mounting bolts" cos thats what I am talking about.
What car exactly and std callipers or not?
RW
RW
no it doesnt bolt, this pin goes through the bottom of the caliper and has a head on it to stop it sliding straight through, then it has a small hole to put an R-clip in to stop it sliding back.
Simple enough mate, get a good sized drift onto the head of the pin and wallop it to get the pin moving then get a parallel punch slightly smaller in size than the hole the pin goes through and hammer it out.... if it wont come out your not hitting it hard enough
Never had a problem with these before and have probably done several hundred of them through the years !!!!
