Not for the squeamish,lol .
Old 01-07-2008, 06:45 AM
  #41
Turbosystems
Super Moderator
Turbosystems's Avatar
Originally Posted by LINCOLN
Interested in this as I have a basemap by AB that has the following;
2 bar (absolute) = 14 btdc
2.6 bar (absolute) = 7 btdc
Is this in the "ball park"?
no
would be more like 14 degrees at 3.2 bar absolute for a 7.2:1 @7500 rpm
I would say you meant 2 bar boost not absolute
Old 01-07-2008, 06:53 AM
  #42
LINCOLN
LINCOLN's Avatar
Originally Posted by Mitsy FQ
no
That is why I asked as the map definately says manifold absolute pressure and start at 140mbar and finishes at 2600mbar.
Therefore the map is only for 1.6 bar boost or am I missing something?
Old 01-07-2008, 06:54 AM
  #43
LINCOLN
LINCOLN's Avatar
Then again it is a basemap!!
Old 01-07-2008, 07:13 AM
  #44
Turbosystems
Super Moderator
what ecu is your base map from
Old 01-07-2008, 07:15 AM
  #45
LINCOLN
LINCOLN's Avatar
Pectel T2.
Old 01-07-2008, 07:16 AM
  #46
Turbosystems
Super Moderator
so a base map not for a low comp yb
Old 01-07-2008, 07:17 AM
  #47
LINCOLN
LINCOLN's Avatar
Edit - I did pass on the spec... stage 3 stuff with low comp (initially set up on a engine dyno - then increments to 500bhp).
Did not think 0.3 cr would have made huge difference but was wondering as 7dbtc was very low - hence the origianl question.
Old 01-07-2008, 07:31 AM
  #48
pa_sjo
Colossal Pervert
pa_sjo's Avatar
You wouldn't map the car to run at 7 degrees, you'd have that in the higher load areas just incase you overboosted. It's a safety thing.. As per Mitsy, I ignored the absolute comment, as the figures are more suited to relative pressure.
Old 01-07-2008, 07:37 AM
  #49
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
pa sjo,
what is it you do for a living as you seem extrmeemly knowledgable and clued up? YOu in the tuning game or just a very competannt diy enthusiast?
Old 01-07-2008, 07:42 AM
  #50
pa_sjo
Colossal Pervert
pa_sjo's Avatar
It's just of personal interest to me
Old 01-07-2008, 07:43 AM
  #51
CossieRich
CossieRich's Avatar
good stuff
Old 01-07-2008, 08:00 AM
  #52
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Puddy,
Did you / do you run nitros? For some reason, I always thought you did?
Old 01-07-2008, 08:03 AM
  #53
Turbosystems
Super Moderator
lincoln don't take this the wrong way but you seem very retarded ............................for your boost level,lol based on the small amount of info you have given us.we really need to see the whole map and it's multipliers
Old 01-07-2008, 11:33 AM
  #54
LINCOLN
LINCOLN's Avatar
Nice one.
No global mutipliers (or adders)
Obviously there are ACT and water temp correctors.
800 1000 1500 2000 2500 3000 3500 4000 4500 5000 5500 6000 6500 7000 7500 8000
2600| 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00 7.00
2400| 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00 10.00
2200| 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00 12.00
2000| 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00 14.00
1800| 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00 16.00
1600| 14.75 14.50 15.25 15.75 16.75 14.75 14.75 14.75 14.75 14.75 14.75 14.75 14.75 14.75 14.75 14.75
1400| 15.75 15.50 16.25 16.50 17.50 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00 15.00
1200| 16.25 16.75 17.50 18.50 19.50 17.00 17.00 17.00 17.00 17.00 17.00 17.00 17.00 17.00 17.00 17.00
1000| 17.00 17.50 19.25 20.75 22.00 22.75 22.75 22.75 22.75 22.75 22.75 22.75 22.75 22.75 22.75 22.75
800| 16.00 16.75 18.00 20.00 21.75 23.50 23.50 23.50 23.50 23.50 23.50 23.50 23.50 23.50 23.50 23.50
600| 18.00 18.25 18.75 20.00 21.25 23.00 23.00 23.25 23.75 23.75 23.75 23.75 23.75 23.75 23.75 23.75
400| 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00
300| 23.00 16.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00
220| 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00
180| 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00
140| 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00 23.00
I wanted to get the pectel going on my spare engine on an engine dyno, then change the inlet for rs500, turbo for t4, cams, ported cylinder head and then new bottom end. I just had too many variables and not enough experience but plenty of time and patience - after all it is a hobby.
Old 01-07-2008, 11:43 AM
  #55
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
As a base map to make the car start and run it looks perfectly good and lets face it, Ahmed is great at mapping so its unlikely to be anything other than what you asked for.
However, It would be dangerous to assume anything at all purely from the information you have given due to the immense number of additional maps present in the Pectel T series ECU's that can add or subtract from that map. For interest, i will try and BTTT a topic i did once all about such things...
Old 01-07-2008, 11:49 AM
  #56
Administrator
Found it:
https://passionford.com/forum/general-car-related-discussion/30468-fao-markk-ref-pectel-t6-2000-maps-enclosed.html
Old 01-07-2008, 11:54 AM
  #57
LINCOLN
LINCOLN's Avatar
I know that it is only a base map.
Just wanted to get thoughts from the pro's on it.
When i start tweaking it live just wanted to get an idea from you guys what to expect. I am going to be pretty worried about det which is why I wanted to get running on spare engine.
Old 01-07-2008, 12:01 PM
  #58
LINCOLN
LINCOLN's Avatar
Thanks for the input Stu.
However, the T2 map that I have for ignition has only the above map and ACT (where 40 deg is zero) and Water temp adders (where above 50 deg is zero)
Nothing else to effect ignition.
Old 01-07-2008, 12:07 PM
  #59
pa_sjo
Colossal Pervert
pa_sjo's Avatar
If you're worried about det, then listen for it!
Old 01-07-2008, 12:10 PM
  #60
LINCOLN
LINCOLN's Avatar
Yes mate
Old 01-07-2008, 12:16 PM
  #61
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
There are plenty of igntion corrections in T2, here's ther global one..
Old 01-07-2008, 12:20 PM
  #62
LINCOLN
LINCOLN's Avatar
By the time you have heard det you are too late.
My hack take on how i will blow up my spare engine...............
Take a base map.
Adjust fuel map for desired lambda.
Then adjust ignition timing for best torque.
The adjust fuel map to for the timing changes just made.
The adjust timing for best torque.
Repeat ad nausem and hope that the correctors that AB has already done a pretty close. The do seem to make sense with the physics.
Old 01-07-2008, 12:21 PM
  #63
LINCOLN
LINCOLN's Avatar
Yes mate but not used in the map i have - only the ones I have listed.
I.E. - AB has not used any other ignition correctors apart from those already mentioned.
Old 01-07-2008, 12:37 PM
  #64
LINCOLN
LINCOLN's Avatar
Just realised sorry for hijack!!
Stu can you clean this up?
Old 01-07-2008, 01:09 PM
  #65
Mike Rainbird
Caraholic
Nice one.
Hi Linc,
Just spoken to Ahmed and he has advised me that he supplied this map as being for an absolutely bog standard car with no mods apart from 803 injectors and 3 bar MAP sensor with a designed peak boost of 1.5 bar .
It is in no way shape or form designed for anything else other than the above.
Old 01-07-2008, 01:41 PM
  #66
Turbosystems
Super Moderator
looks like a perfectly good safe base map for people to map their own engines
Old 01-07-2008, 05:47 PM
  #67
puddy
puddy's Avatar
Puddy,
no mate,gas is fitted but I ain't used it yet as I was struggling for grip without it !
Very intresting stuff this mapping lark,but I paid a lot of money for some one else to do
mine !
puddy
Old 01-07-2008, 05:51 PM
  #68
Turbosystems
Super Moderator
i would be investigating your fuel system first and checking the pressure in your low pressure system and fitting the 3 mm jet as wes has suggested only because i told him before lol
I'd also like to see some pics of your tank in order to comment further
Old 01-07-2008, 06:44 PM
  #69
wes
wes's Avatar
Yes this is true, I know this because i got my swirl pot form you
Old 01-07-2008, 06:50 PM
  #70
Mark Shead
Mark Shead's Avatar
Puddy
Didnt you have MSD ignition system on the car and was it dyno'd with it,
I never let a car run hard if it has been mapped on the dyno unless I have live mapped it.
Mark
Old 01-07-2008, 07:44 PM
  #71
rapidcossie
rapidcossie's Avatar
Must have been something way off to have went so bad on the first extended period of WOT in the higher gears.
Old 01-07-2008, 08:30 PM
  #72
RickyLee53
RickyLee53's Avatar
Damn! You mean i've looked like a clown wearing DET can's for all this time when really if it was going to break before i heard it?
P.s. I know what DET sounds like
Old 01-07-2008, 08:48 PM
  #73
dovboy
dovboy's Avatar
mine !
puddy
fuel system would be the first thing to check before blaming the map.
Old 01-07-2008, 09:08 PM
  #74
pa_sjo
Colossal Pervert
pa_sjo's Avatar
In all fairness though on a big power engine that's relatively on the edge, a nasty crack of det at 7500rpm can be enough to lose a piston without you even hearing it... but there'd have to be something seriously wrong with the spec or map for that to happen (or a failure, like a MAP sensor going).
Old 01-07-2008, 09:39 PM
  #75
PAUL V
PAUL V's Avatar
Is it just me or are you all barking up the wrong tree ?
There is just 1 piston that has failed right ? well if it was the ignition map would not all 4 look the same ??? .
Now if the fuel injector was not flowing right would that not also cause the problem??
Puddy am i also right in saying you specked the engine had all the machine work done and built it yours self and gave it to Harvey to set up on his dyno for you ?
If this is the case and you have done 1000 miles on the engine then what are you pointing the finger at Harvey?
Old 01-07-2008, 10:40 PM
  #76
LINCOLN
LINCOLN's Avatar
Hi Linc,
Something lost in translation then......
AB is horrible at returning correspondance (i.e. non-existant - but perhaps i have overstayed my welcome).
Old 01-07-2008, 11:10 PM
  #77
puddy
puddy's Avatar
No.3 cyl is the worst,but all 4 pistons are damaged to an extent so I don't think its one
injector that is the problem.
As has been already said,it behaved perfectly on the road and I will be checking the fuel
system thoroughly when its back up and running.
I am not blaming harvey,but my 1 st thought was too much ignition as all the ring lands are
crushed,thus pinching the rings and burning the side of the piston.
I do use a digital 6 msd ignition on my car,but this can only be used to retard ignition ,such
as for nitrous applications.
Cheers for the positive thoughts,this ain't a witch hunt and I would happily use harvey and
ahmed again,but as mr shead says, with a full live mapping session afterwards.
puddy
Old 01-07-2008, 11:17 PM
  #78
pa_sjo
Colossal Pervert
pa_sjo's Avatar
Did Harvey or AB advise you to get it checked in-car? Just out of interest.
Old 01-07-2008, 11:27 PM
  #79
puddy
puddy's Avatar
No,but it was dyno'd a few years ago now,sat in the shell for quite a while whilst I plumbed
it,made and fitted the fuel system,and completely wired it .
puddy
boeb
09-01-2020 05:11 AM
tankybaby66
06-02-2016 02:24 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
Neil Clark
21
01-10-2015 07:02 PM
Fudgey
21
30-09-2015 06:19 PM
Quick Reply: Not for the squeamish,lol .
