Engine block advise please
Old Oct 29, 2004 | 12:09 PM
Spiky's Avatar
Spiky
Default Engine block advise please
on my block (200) where the powersteering mounts on it, on the passenger side, there is a plate with two screws which covers a hole in the block,
think someone said it was the old pinto fuel pump mount (mechanical)
well what i need to know is
is there a paper gasket there or do i just use some of that blue sealent (sorry forgot the name begins with H though )
also on the driver side, on my 205 blove there was a plug i could remove to mount my breather, but there isn't one on mine???? as i'm not gonna use the knock sensor can i plumb the breather in there????
Old Oct 29, 2004 | 12:39 PM
CosKev3's Avatar
CosKev3
That plug deffo there on both the 2oo blocks I've had,are you sure it ain't
hiding under the wiring that goes to knock sensor as there is a 'c' clip on the top
of the plug that is holding the wiring that goes to knock sensor
Never noticed that other plate your on about though
Old Oct 29, 2004 | 12:40 PM
cossiestu's Avatar
cossiestu
Sure my block is blanked off there...? Should know, ive just finished building it...
Are you thinking of blue hylomar?
Old Oct 29, 2004 | 01:41 PM
pugo's Avatar
pugo
hylomar blue will be fine and yes it is where the mechanical fuel pump sat
Pugo
Old Oct 29, 2004 | 01:51 PM
Spiky's Avatar
Spiky
thats the stuff
so no paper gasket??
sweet, one thing less to worry about
Old Oct 29, 2004 | 01:55 PM
3drstretch's Avatar
3drstretch
As above mate.Use gasket sealant and make sure it a good surface.This is where i had a leak as the bolts worked loose .And the breather hole should be there as mine is plumbed in there.
Old Oct 29, 2004 | 02:04 PM
Spiky's Avatar
Spiky
3drstretch, working now then
Spiky's Avatar
Spiky
oh and trust me, there is not a breather hole like my saff engine
St3V3_C's Avatar
St3V3_C
Is that it - the square plate?
No gasket shown there either.
Old Oct 29, 2004 | 02:05 PM
Spiky's Avatar
Spiky
no it's not the square bit, it's the section where no13 attach's to the block
Old Oct 29, 2004 | 02:19 PM
St3V3_C's Avatar
St3V3_C
OK, still no gasket
As I said last night (and these guys above) about the diff bit - blue hylomar is great.
Old Oct 29, 2004 | 02:21 PM
Spiky's Avatar
Spiky
Old Oct 29, 2004 | 03:03 PM
3drstretch's Avatar
3drstretch
Yep all workin.BT had sent me E-mails with the right info on.
You sure you got a 200 block as i've never heard of them without the breather bolt. If the knock sensor is there.Is there a clip that the wire off knock sensor clips into as this bolts to it.(i think)
Old Oct 29, 2004 | 03:47 PM
Spiky's Avatar
Spiky
there is yes,
will check next week when back in wales
Adam-M
Aug 26, 2015 05:53 PM
borboyous
Aug 22, 2015 11:17 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
