Twin port external wastegate and air injectors
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
All you should have to do is pipe the outlet of the air injector to the bottom port of the external wastegate. If you had a boost controller with a 3 port setup you could vent the return (bled off air) into the top port of the wastegate to increase the lift pressure. Hope that helps
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
caprixpack
25-09-2015 07:53 PM
