Camber & Suspension
Camber & Suspension
Hi all, I have spax suspension (cheap but does the job) on my S2 and this has changed my camber shit loads so that the tires are wearing unevenly on the inside of the tires really quick! Any one know where I can buy adjusters for this so I can correct it a bit.
Also my back end likes to slide out allot in the wet, any ideas on how to stop this as much (good fun but want better cornering ability)??
cheers!!
cheers!!
im sure adjustable TCA are available for the mk4... check burton power
also this is the sort of thing Christian & Becky/APT will probably know about off the top of their head.
also try ZOO they do all sorts of weird n wonderful things, dunno if they do RST stuff tho...
you might find the back a bit more of a struggel tho...
i assume the car's been dropped more than about 30mm?
no its only dropped bout 25mm and took it to fords for a full wheel alignment back and front etc and they tried to correct the camber but said there wasn't enough adjustment.
I will check out burton power then, see if they have anything useful
SMILER258
28-09-2015 09:04 AM
