Hydraulic clutch conversion people
Monte Geek
How do you get around mounting the reverse switch on the gearbox with the master cylinder in the way?
I seem to remember Martin Hadland saying find a 2wd switch?? what exact model as they seems to be a few and none look like they would fit??
Thanks
Thanks
if you bought this conversion from reyland then u have fitted the slave cylinder upside down. I did exactly the same & it wouldn't bleed up properly. in this case the bleed nipple does not go to the highest point something to do with the internal drillings
Monte Geek
Tony I tried early and got no reply and assumed was becasue Martin was away, I'll call back later.
ps can you read Martins PM's? if not I'll forward you the one I sent
