Explain-----> Air injection
As above
I've read about it but i don't know what it is, so can someone here explain it with pics maybe.
Cheers Ruud
Cheers Ruud
Air injectors
are just large normal fuel injectors used as air flow control
when controlling boost levels via the actuator.
Usually found in pairs side by side.
They give precise control of boost at all levels/rpm as mapped in the ECU.
Kind of an expensive AMAL valve if you know what that is !
This is done by pulsing the injectors open/closed very fast and varying the
open time which averages out the air flow to the actuator and thus alters
boost pressure.
boost pressure.
Air INJECTION
is used on some cars to help the cat warm up quicker when the engine is cold.
This is usually done with an electric pump.
This was fitted to reduce exhaust emmisions.
This has NO performance advantages (was used on the Mk5/6 RS2000)
Air INJECTION
cheers guys!!! i always wondered how air injectors worked!
so can you use boggo fuel injectors i assume?! as your just allowing air to pass through yeah?!
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
