2WD Manifold or 4WD Manifold?
go with the 2wd then but you will need the correct down pipe if your going with 4wd running gear.you will also need a turbo damper.
the focus is ok but not a cossy tho
2wd exhaust manifold is the better of the two for flowing. And EECIV (Small Turbo Escort) is the best flowing Inlet Plenium. Anything better than those and you need to start going aftermarket.
Both will easily flow well over 400bhp.
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
caprixpack
25-09-2015 07:53 PM
