t38?
Old 25-05-2008, 10:13 AM
R5FORD
R5FORD's Avatar
Default t38?
what kind of power can a t38 produce?
Old 25-05-2008, 10:14 AM
bigpower
bigpower's Avatar
450?
Old 25-05-2008, 10:15 AM
Kelv
Almost there!
Kelv's Avatar
UT T38 is alledgedly good for 450 ish BHP
a TT T38 made 466BHP on YUM a couple of years back.
R5FORD
R5FORD's Avatar
i have no idea
Old 25-05-2008, 10:16 AM
R5FORD
R5FORD's Avatar
hmm im decidning what to go for a gt30 or a t38.. dont really want the headache of exteral gate.
Old 25-05-2008, 10:17 AM
COMEDY DAN
No1 Blower.
COMEDY DAN's Avatar
Mine made over 450 bhp.
It was a proper T38 too, from Turbo Technics the real deal.!
Old 25-05-2008, 10:23 AM
Kelv
Almost there!
Kelv's Avatar
youve always got the option of a GT30 internally gated, then with the .63 Housing.
spools up as quick as a T34 and capable of giving a healthy 450 ish BHP.
im sure Paul Ripley went for that turbo and made a few horses short of 500.
Old 25-05-2008, 10:28 AM
R5FORD
R5FORD's Avatar
internally gated?? iv been told that the internal gated gt30 isnt as good as a external?? can anyone give me reasons why this is.. i know a external gated one can have more precise boost..bbut anything else?
Old 25-05-2008, 12:24 PM
15D
Italian convert
15D's Avatar
Marco (Polo) runs an internally gated GT30 IIRC
Old 25-05-2008, 12:40 PM
R5FORD
R5FORD's Avatar
aahhh maybe i might see what he says about it.. or then agian i might just go for external gated.. depends on the sitution with the car
Old 25-05-2008, 02:11 PM
NEIL A
NEIL A's Avatar
What kind of power are you looking for?
If over about 430 i would go for either a GT30 or RB T4, that way you have more scope for future mods and also wont be running the turbo as hard.
Old 25-05-2008, 04:55 PM
RWD Pete
RWD Pete's Avatar
my tt t38 is pushing about 400 at the wheels on my saff
Old 25-05-2008, 07:32 PM
gibbo frst
gibbo frst's Avatar
i have a tt t38 on mine it is loads beter than my old t34... i have been in marco's 3door with the gt30 internal wastegate and it came on boost far quicker than mine with a similar spec engine... .. if i was buying brand new again i would choose the gt30...
Old 25-05-2008, 07:47 PM
rst-g
ZETEC TURBO
rst-g's Avatar
wots the diff gt30/gt35?
Old 25-05-2008, 07:50 PM
Miller 3
Miller 3's Avatar
about 100 hp lol
Old 25-05-2008, 08:33 PM
R5FORD
R5FORD's Avatar
prob around 450-500.. my main concern is the transmission side of things..but that seems to be sorted now
Old 25-05-2008, 09:11 PM
RWD Pete
RWD Pete's Avatar
Got a near brand new tt t38 for sale in for sale section
Old 25-05-2008, 09:24 PM
R5FORD
R5FORD's Avatar
not sure if he t38 is going to give me the scope i need now
Old 25-05-2008, 09:34 PM
escort700bhp
escort700bhp's Avatar
i have one running 496bhp
Old 25-05-2008, 09:39 PM
trevCOSS
trevCOSS's Avatar
as said a number of times gt30 internal i suspect would be the way to go, although i didnt
Old 25-05-2008, 09:41 PM
R5FORD
R5FORD's Avatar
and is that on the limit??
Old 25-05-2008, 09:43 PM
Kelv
Almost there!
Kelv's Avatar
thats like asking what the difference is between a T34 and a T4.
Old 25-05-2008, 09:45 PM
escort700bhp
i would think so
8 803 injectors and bd15s
cheers
Old 25-05-2008, 09:47 PM
R5FORD
R5FORD's Avatar
yh i dont wnt a turbo thats gona blow up in 6 months
Old 25-05-2008, 09:57 PM
Jay,
Sponsor
Jay,'s Avatar
gt30 is the way to go better spool up and better top end
Old 25-05-2008, 10:03 PM
R5FORD
R5FORD's Avatar
seems gt30 it is.. just got to decide internal or external
Old 25-05-2008, 10:16 PM
oohogwash1
oohogwash1's Avatar
I checked on GT30, I know a guy with GT30 that gets 425 at wheels on 23lb boost with top condition engine... He won't take it much higher in boost like his older T4 for a number of reasons.
I know others with GT30 that found that its max efficiency was lower boost (ie, it pushes more air at less boost, boost is not really the ultimate figure to go by) and that at high 20s it loses efficiency just generating heat... not pushing more air.
I suspect that the 425-450 is about its reasonable limit with great spool up... if that fits your needs that would be nice.
If not: if GT35 is like T4 as mentioned think about that one, depends on your area and usage... I have been recommended to use GT35 with std ex cam, and BD16 inlet and mild porting... Currently thats my choice, but I have occassional driver, track days and dyno days... as my intended usage, that is if I can ever put the car back together
Old 25-05-2008, 11:06 PM
R5FORD
R5FORD's Avatar
my will be used near enough everyday..so want it respeonsive.. think a gt30 will meet my requiremtens 425 atw seems a nice figure
Old 26-05-2008, 05:57 AM
Jim Green
Jim Green's Avatar
Figures quoted for the two T38's (Universal Turbos & Turbo Technics) are accurate. I had Universal Turbo's T38 on the sapphire engine that Karl Norris built up, 7.5:1cr, Ported Head, Karls Cams, Grey Injectors, and it made 428bhp when it was only just run-in and still a little tight. Now (5,000 miles later) it's in the hands of Maxest it's producing more (440 BHP + If I remember correctly) due to Black Injectors and Autronic Management, but still on the T38.
If I was building the same engine today, I would use the GT30, for the faster spool up and slightly better top end. But bear in mind that originally both versions of the T38 were built for engines in the 400 - 450bhp bracket, they do exactly what they were designed for and both versions have proved that they're a very reliable turbo.
Old 26-05-2008, 07:34 AM
Roosie
500bhp Cosworth in making
Roosie's Avatar
anyone got any pics of a gt30 on a cossie?
Old 26-05-2008, 07:44 AM
Miller 3
Miller 3's Avatar
hears one of mine
Old 26-05-2008, 07:51 AM
PGT
PGT's Avatar
these type of threads are facsinating but the stuff about the GT30 is confusing. there is a GT3076 which comes with 3 exhaust housing options and there is a GT3071 which also does. The 71 & 76 refer to the wheel size etc
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
so which turbo are we talking about?
Old 26-05-2008, 08:11 AM
Roosie
Roosie's Avatar
fook there is loads to look at fook knows what i want.
Old 26-05-2008, 08:24 AM
Kelv
Almost there!
Kelv's Avatar
Doug, looking good mate
and a small crappy picture of mine.
Old 26-05-2008, 10:54 AM
R5FORD
R5FORD's Avatar
kelv couldnt they get the welding on the 2wd manifold better?? or isit just my eyes as the pictures small?
Old 26-05-2008, 11:04 AM
Kelv
Almost there!
Kelv's Avatar
the welds are perfect mate, its possibly the picture.
thats a reyland manifold.
Old 26-05-2008, 11:14 AM
R5FORD
R5FORD's Avatar
ahhh seems the picture then.. im thinking of going external on mine now.. is there much space between the brake fluid resevoir and the wastegate??
Old 26-05-2008, 11:27 AM
Vic
Vic's Avatar
go external as u get to free up some hp
Old 26-05-2008, 11:50 AM
R5FORD
R5FORD's Avatar
vic- you gone external mate?
Old 26-05-2008, 05:34 PM
mercurys2
mercurys2's Avatar
escort700bhp please respond to my email as a matter of urgency
Quick Reply: t38?
