Vauxhall C20XE - COSCAST Heads
Guys,
How can you determine whether a motor has a COSCATS head either by records or physically ? I'm looking at a 1997 Calibra later (which I thought would've been Ecotec anyway) but the guy (who knows nothing about cars) tells me the top of the engine is definately red. I know the later XE's had GM heads just wondering how to tell ? Cheers Paul :king: |
it will have coscast stamped on the head somewhere matey
Core plug underneath the distibuter IIRC. Doubtful on a 97 car, there aint that much difference anyway!
GM Cylinder Head
http://www.v-tuning.com/images/GMHead.jpg Coscast Cylinder Head http://www.v-tuning.com/images/COSHead.jpg As mentioned no difference in performance to be had. 97 car will probably have the ecotec engine fitted though (straight spark plug cover) unless someone has been playing beforehand. |
stamped on it.
dont think 97 cars had them tho, unless its been changed |
The stamping isnt easy to identify when the engine is in the car, best way is by looking for the coreplug as not normal has illustrated.
If its a 1997 produced car then it WONT have left the factory with a redtop in it, it will have been an ecotec. |
The ecotec cam cover is red isn't it? I had a lad in my shop who said he had a 'red top' in his corsa, but it was a red coloured ecotec.
Cheers for replies guys......
I'll see what later brings, I was sure it would be an Ecotec for this year but he said the top of the engine was red ? He admitted to knowing nothing about engines as said, but ''if'' you can get an ecotec with red plug cover that would explain it. He's only round the corner so I'll go look anyway. If it turns out to be an Ecotec is it worth buying ? I've read more bad than good about these lumps.......... is it founded info about the ecotec's ? |
the ecotec is a black cover mate,
the red plug covers are on the XE redtops |
Ignore the colour, the XE also came with a black plug cover on later engines, although called a "redtop" in slang, they werent ever called so by vauxhall and hence vauxhall had no reason to stick to keeping the plug cover red.
The key thing is the SHAPE of the plug cover. Xe one is like: __________ | Ecotec one is like: __________ Take NO notice of colours at all. |
Cheers Chip :king:
Just to make it even more clear:
20XEV (ecotec) http://www.ecotekplc.com/images/Omeg...tek.%20003.jpg 20XE (reptop) http://www.xstyle.co.uk/media/DIR_55...13-01-06~x.jpg Other differences are obvious such as the SFi box instead of the black inlet pipe, but those things are sometimes swapped around so arent as definitive. |
Right, just got back and it was indeed an Ecotec (with a black cover) nothing was red so he must be colour blind :wall: waster of time anyway the car was a pile of sh*t, didn't even advertise the fact the n/s quarter looked like it'd had a previous liason with a lamp post :roll::cry:
Thanks for all the help guys :top: |
Originally Posted by Chip-3Door
(Post 3235327)
© 2024 MH Sub I, LLC dba Internet Brands
