can a L8..
Testing the future
you need a live mappable RP Lab L8 so that anyone can map it - link to their website in my sig. they probably don'y have an australian distributor yet, but you could probably buy direct if you speak to nikola and say that nick sent you
or chip has one for sale
Football Cwazy
Some of the better tuners could supply you with a chip that would be pretty good for that kind of power, you'd need to provide exact specs though and still have it looked at.
Just get Stu to do you a chip and get the fueling checked by someone who knows what they are doing. Stick to tried and tested things like 7.2-1 comp ratios and known Turbos like GT30's and T4's and I BET Stus chip would run the car superbly and TOTALLY safely.
Save you a load of money and hassle!
Sell the following Items:
8 small injectors.
2nd fuel rail
twin reg
8 Inj Loom
8 inj Plenum
8 Inj L8 Super 8 board
For lots of cash...
Buy:
4 big injectors.
Plenum spacer
Std fuel reg.
For far less cash.
Then add new features to chip that super 8 cant have such as Anti Lag, Lauch Control and Closed Loop and you may still even be quids in.
Better & cleaner running with better features for less cash. Job done.
8 small injectors.
2nd fuel rail
twin reg
8 Inj Loom
8 inj Plenum
For lots of cash...
Buy:
4 big injectors.
Plenum spacer
Std fuel reg.
For far less cash.
Is there no one in auz near you that can map it?
They are pretty intot their fast skiylines and scoobies over there so must be some good mappers.
Just se it as a waste of money to spend loads on an engine and parts then go with an off the shelf chip that will never get the optimum from you cash.
