fuel pump re-wire question
evening;
going to get an uprated fuel pump for the 2wd cossie, but i've heard its best to re-wire it so it draws the correct voltage all the time rather than the volts dropping
anyone done this? what's involved and are there any instructions anywhere?
help would be appreciated
Ta
Ta
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Briefly - you need to run a fused 12v feed directly from the battery via a relay to the fuel pump +ve.
Use your original fuel pump wiring to switch the solenoid in the relay.
-ve from the fuel pump directly to the chassis.
JK12
33
26-04-2021 12:09 PM
03-11-2015 04:08 PM
