AEROQUIP FITTINGS TO A OIL BREATHER & FITTING TO SMALLT
HI COULD SOME ONE PLEASE TELL WHAT DASH SIZE FITTINGS TO WELD TO OIL BREATHER I THINK IT IS -10 BUT IAM NOT SURE.ALSO CAN YOU CONNECT A PIPE TO THE BACK OFF THE ROCKER COVER AS IT JUST HAS THE COIL PACK COVER ON THE SMALL TURBO MODEL
CHEERS PAUL
CHEERS PAUL
should -10 be used for all oil breathers or just for cossie oil breathers?
i was looking at using -8 as that is 1/2" bore tube and is the same as std ford piping as fitted to the CVH...
would -8 or -10 be best in this case?
09-10-2015 07:38 PM
JoeyBoyden
18-08-2015 10:52 PM
