what does an escort cos feel like to drive...?
#43
the E30 wasnt the best handling car in the test tho...
...but it won overall as 'best driver's car' though didn't it?
#45
Originally Posted by Alps Pacino
Best drivers car doesnt mean its a good car it just means its fun to drive. Like my 106 rallye its utter wank but is fun to drive lol
Just think it's amusing the way the E30 M3 has gained icon status over the years............from the same journos who placed it behind a Sierra when both were new
#46
people seem to forget that most cossies are now gettin on for 15-20 years old, a lot of cars are still on thier original bushes and suspension - no wonder they handle like shit, with all the wear and play in tcas, bushes, bearings etc etc then they WILL drive horrid! The difference a steering rack made to my mates 4x4 saff was amazing, the steering went from what felt ok anyway to pin-sharp
#47
Originally Posted by Bullett
mike,whats huge money?
The minimum would consist of poly bushing the car, the same suspension I have, 6° rear beam, adjustable TCAs (consisting of new Ford TCAs modded, not the cheap aftermarket ones that seem to last five minutes), plus full geometry set-up and including fitting.
On a 2wd Saff thats only used on the road, where would you stop?
It already has 6° rear beam, koni shocks, ahmed/leda springs (fast road ones), and polybushed throughout.
Would you get adjustable TCA's and leave it at that for a road car?
Also what tyres do you reccommend for road use?
#48
Caraholic
Originally Posted by NEIL A
Mike on a road car running Cossymad spec GAZ coilovers how much of a change would the back beam make over the set up im running justnow. Im running shims on std beam, adjustable tca's and fully poly bush including diff mountand front and rear braces. Will hopefully soon be running AVA spec compression stuts and tca's aswell.
Originally Posted by RWD_cossie_wil
I need a decent rear beam next, but thats going to have to wait a bit as I'm fookin skint from sorting the drivetrain ...wanky 4x4
Mike, have you got the Adrenalin frame connectors?
you are running coilovers arent you mike?is this different on a saff to an escy then?i didnt think you could run coilovers on the rear of a saff due to shonky seperate spring and shock.
what has yours set you back in total if thats not rude?
Originally Posted by JTECHSAFF
how the fook do you do the little degree sign on a querty keyboard ive been looking for ages
Originally Posted by smidsy
Mike,
#50
Caraholic
do frame connectors make a big difference?
#52
Eagle had them on his 4x4 and commented favourably if you search back. There is also some bumph on Danny's own site if you are interested
#54
Caraholic
Mike, do you use front roll centre adjusters, or does the rear beam negate the need for them?
Next you'll want all my beauty secrets .
#56
