Tips: removing a cross threaded glow plug with a rounded nut
Old Oct 28, 2007 | 11:18 PM
EssexBoyRacer's Avatar
EssexBoyRacer
Default Tips: removing a cross threaded glow plug with a rounded nut
Ford Escort TD (endura)
no. 3 glow plug is cross threaded (not by me). I managed to get it about half way out before I rounded off the nut on the plug.
Bit of a school boy error in that I used a 12 point socket rather than a 5/6 point one.
Any ideas what I can do to get it out?
Old Oct 28, 2007 | 11:26 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Can you not get on it with a 6 point one?
Old Oct 28, 2007 | 11:27 PM
scruffythefirst's Avatar
scruffythefirst
weld a nut to it
Old Oct 28, 2007 | 11:43 PM
EssexBoyRacer
not any more! its just a round nut now.
Old Oct 28, 2007 | 11:44 PM
EssexBoyRacer
Originally Posted by scruffythefirst
weld a nut to it
that crossed my mind, but dont have access to a welder unless I take it to a garage.
Big Will_'s Avatar
Big Will_
EssexBoyRacer
Proper job of it then
Weld a nut on then - as mentioned above
Old Oct 28, 2007 | 11:59 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
use mole grips... but make sure they're big ones
Old Oct 29, 2007 | 12:02 AM
EssexBoyRacer
tried that, ended up snapping the welds on the grips from trying to get the grips tightened up enough.
bought 2 more today!
Old Oct 29, 2007 | 02:52 AM
mrjenrst's Avatar
mrjenrst
thermite will do it
Old Oct 29, 2007 | 07:12 AM
dojj's Avatar
dojj
Resident Wrestling Legend
take the head off and take it to a shop
if you've crossed the threads at some point it might not be as clean a job to remove it and you might have got some shit down into the bores
we had a 300 td merc in a few months ago and the glow plug striped it's threads on the way out
it totaly fucked the piston as bits if the thread mashed themselves into the crown and the chamber where the valves sat was all fucked as well
with a bit of heat everything came apart and all it needed was a new piston, but there was blow torching to buggery going on with that head to heat it up enough to get the plug out and then we had to get it checked to see if it had warped or not
Old Oct 29, 2007 | 07:36 AM
900ss's Avatar
900ss
RWD Racer
If its badly rounded use a 6 sided socket the next size down
obv make sure you whack it on hard b4 you try to undo.
Old Oct 29, 2007 | 07:50 AM
dojj's Avatar
dojj
find a sacrifical socket you can heat up
then sitck it onto the end of a sacrificial extension and heat teh fucker till it gets hot
then whack it onto the end of the plug
the heat will let it warp a little bit so that it will fit better
then let it cool down a bit so it compresses itself onto the nremenants of the nut
they try
if all else fails, buy another car
Old Oct 29, 2007 | 09:03 AM
Big Will_'s Avatar
Big Will_
Fuck me Why didn't he think of that
Old Oct 29, 2007 | 12:31 PM
EssexBoyRacer
fpmsl! cheers guys! only had the car a month so thats an expensive glow plug!
it runs fine half way out (just misses a bit for the first 10 - 15 seconds when its really cold) and as its a run around until I sold my BM im tempted to just leave it!
I did try the smaller socket job but couldnt get the angle to get it on properly.
JoeyBoyden
Jan 4, 2024 02:36 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Aug 29, 2015 08:16 PM
Bosch
Aug 4, 2015 05:14 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
