Piston Rings
they should be set so the gap in the rings are oposite each other as far away from each other as they can be to reduce compression loss i hope u understand what im trying to say im not too good at explaining things lol
Do u mean so all 3 are as far away from each other or like the top one is at one side of the piston the 2nd one is at the other side then and then the oil one is sitting at the same as the top ring?
Of do u mean like a 1/3 gap between all 3 rings?
Thanks
Thanks
Thats how ive been taught to do it that way it harder to loose compression
Gaps should be set 120 deg out from each other.
ie 2nd comp ring 120 out from top comp ring.
oil control ring 120 out from 2nd comp ring.
Hope this helps.
Hope this helps.
*** Sierra RS Custard ***
Hope this helps.
Hope this helps.
The place you want the gaps though is either side of the pistons, as its less exposed as the piston comes round TDC and rocks slightly, doing it your way, they cant be.
Hope this helps.
Hope this helps.
deathrider666
28-09-2015 06:12 PM
