how to do a pressure checked
you need a compressor, and something that you can fit where the airfilter goes with a air fitting on it!
let the compressor pressurise the whole of your inlet system to 1.5 times your boost pressure, then go around all joints with a soap solution in a squirty bottle!
bubbles means leaks
or even easyer, just take it to MSD and they will do it
bubbles means leaks
i've got a box full of different sizes i've needed in the past. from 10mm to 100mm
i use a reg.
Some use a tyre valve fitted in the blocker, with inflator to pressureize
on my cossie i do @ 40 psi, but anything above your boost will be fine.
i use a reg.
bubbles means leaks
bubbles means leaks
what he said but on mine ive put a gauge and tap on the inlet so i can shut it off when up to pressure. nearly took my mates head off when a plug blew out before i had gauge must of got to over 50 psi
plug either end of whatever you want to test !!!
If you remove the intake cam, you can also check to see if all the intake valves are sealing properly during a test.
SMILER258
28-09-2015 09:04 AM
