What AFR on a YB
What AFR on a YB
After the rolling road day at totd I'm curious what AFR you would would prefer to be seeing from a YB on full chat ?
Compared to the Skylines I went with the 3 door seemed a little lean on boost nothing bad was said about it by the operator though
The other thing worth noting is how crap the ecocomy is closed loop is required ASAP !
The 3 door was touching the 12's on full chat.
My Pectel monitor does egt but I'll need a sensor first
Know of any good cheapish EGT's guages Chip ?
Well unless its just starting going wrong it has been like for ages, infact its seen more use on track than most peoples cars on here do in 5 years
Would be interesting to see what Karl and Stu etc look for etc. when mapping.
We'll probably get the innovate plugged into it at some point to see what its doing on the road as it does hold more boost on the road thus maybe making it leaner, who knows
Not my car but I still wouldn't want to see it die for something so easy to sort
*** Sierra RS Custard ***
Phil2400's Saph goes up into the 12s on full boost and that car gets driven harder than just about any car I know, so its certainly possible to run 12s and keep it in one piece, just obviously means you have that little bit smaller margin for any variation in fuel quality etc than if you were a bit richer, on the other hand, its ideal for power!
Originally Posted by dingy
Mine is at 11.6 at full chat with maximum load and boost.
And ecomomy ? buy a diesel LOL
One day of driving that 3 door made me realise how great my lpg converted cavalier is
Are you using closed loop Dingy ?
PS cheers for the info on that map sensor connector
Originally Posted by Chip-3Door
Originally Posted by boXXer
what about n/a cars? what would be considered lean?
is awesome
Does this count for any 2ltr turbo?
Or does it vary through tune, standard, stage one, two, three etc?
IIRC Cossies run around mid to high 11's for full power, any higher and they get too hot (Excessive EGT's)
I think it depends on the inlet, head, exhaust mainfold, combusion chamber design. For example I've seen Turbo'd B16 on a GT30 run 12.5 @ full thottle @ 2bar of boost and the EGT's weren't excessive on 99 octane fuel.
I'm sure someone who know more about it, will explain more clearly (and correctly).
Wants to be a proper pinto if its on 48's IMO
I had 45's on my 183hp pinto and it was shocking on fuel, as it cant really be controlled its why everyone chooses to use throttle bodies and a proper ecu
Carbs for race engines, tb's for road engines
195hp
Not allowed injection in certain classes but yes I agree that if your allowed then throttle bodies are far superior.
Boxxer- Sounds sweet, miss my pinto a lot, but I dont miss the fuel bill
Get it setup properly then you might find its not as bad as you think, mine was great once setup by Pete Baldwin but just too much for a daily driver
Carbs and economy dont really go together in my experience
However after using my mates 3 door for the weekend I can't honestly say that was any good either !
I can't be 100% but closed loop on a Yb must save you a bloody fortune !
Unknown.
Anyone else shed some light?
I don't use closed loop mate, its not needed as the car off boost is very economical
Scooby Slayer- How many miles to a tank are you getting then ?
Or should I say how many tanks to a mile are you getting considering the use your car has had in the last few weeks
when i went to msds in blackpool used a tank and a quarter which worked out 12 to the gallon and thats cruising at 70 to 90 kmh of coarse and the odd fun splurt if you know what i mean.
then on the way back from msd same style driving did 20 to the gallon.
if i proper cruised at a held speed and just tickled the throttle 25 - 30 mpg would be doable i reckon
since last fill up ive done 123 miles and 1/4 tank left although ive been having some fun and still averaged 12 mpg
That really is quite impressive
So your not using closed loop lambda then ?
dont get me wrong flat out cant be much more than 6 mpg it that
but this is the first cossie ive had that doesnt have to be raged to run good. and its the first one ive had that doesnt drip oil from anywhere, hasnt used any oil or water yet done 1000 miles since map and service. and oil doesnt smell of petrol vapour
i can honestly sit in 5th gear at 35 mph and it runs like a sewing machine i kid you not mate
