How do I get Sky TV in another room
Without paying Sky for an extra box
I've got Sky downstairs and it'd be handy to have it in the bedroom too. I wouldn't really need to use the control upstairs as I'd be happy to come downsairs to change channel.
I seemed to remember somebody saying you can utilise the existing wiring that goes to the aerial on the roof to get sky in the bedroom (which is also wired to the roof aerial.
Anybody know how this is done or another way of getting the same result?
Do you want to watch and control Sky in your bedroom whilst the box is in another room? If so you want a Magic Eye as found here: http://www.simplydigital.co.uk/acata...FQF7aAodYD3H2w
You will need to take a coaxial wire from the back of the box to the connector on the magic eye. Then you can switch channels whilst the box is in another room.
You could use an AV sender (http://www.maplin.co.uk/Module.aspx?...704&doy=search) which will send the output of the device (in this case, a Sky box) to the scart input of any TV the reciever module is plugged into, but there are two probs with that.....
1) You won't have use of the remote control, so if the Sky box is downstairs and TV is upstairs, you need to get out of bed, go downstairs to changel channel, turn it off, change volume etc....
2) If your device doesn't have two scart outputs, then you have to manually unplug the scart from tv it is plugged into and plug in the AV sender transmitter scart - pain in the ass!
Originally Posted by cossiegreg1
this is what you want quick its cheep
http://cgi.ebay.co.uk/SKY-DIGITEL-RE...QQcmdZViewItem
go buy the amount of cable you will need to reach from your sky box to your second tv.
stick this device in the back of bedroom tv(ariel socket).
plug cable you in and bobs your uncle.
dont worry instructions come with the kit. its a peice of piss.
I was running 4 TV's off my Sky box until I go an extra box upstairs which I now use for the 3 TV's in the bedrooms. Only 1 "eye" tho as haven't got the signal strength to run 2 "eyes".
Piece of piss to do and if all you want is to run 1 extra TV from a Sky box it'll take 20 minutes max to do the whole job
Steve
Steve
Originally Posted by lardypants
so ive got to runa cable from my box downstairs all the way upstairs....? bollox to that then
Is there another way or can I utilise the cables already running to both TV's from the TV aerial on the roof? There's a double socket in the loft where the aerial lead comes in from the roof, then it's split, one for downstairs, the other for the bedroom?????
not if you definitely want the sky matey, the cable needs to come from the back of the box.
As said, get a digi sender thingy so you dont have to run cables upstairs
weve got it in every room in the house using one box. we did it before this magic eye thing came out but can only watch one channel.
you have to use a arial booster to take the signal round the house
this way you can do it to as many tellys as you want.
PF Idiot Sniper
in my loft there are 2 aerials that go to 2 seperate wall sockets in the house, 1 in living room and 1 in bedroom.
Now for the eye to work you need a connection from the output of sky up to the sky eye which plugs to the tv upstairs.
what you have means that this should be a piece of piss!
run a wire from back of sky box to the aerial socket in living room. go to loft and disconnect both wires from splitter and join them. Now run wire from bedroom socket to tv via sky eye and et voila
now when we move next month its a whole new kettle of fish as i have more rooms to feed. Im gonna get multi room for the 2nd living room but am hoping to use a similar method of using existing sockets to feed kitchen and bedroom. Hope to fuck it works!! lol
Originally Posted by Lambchop
you could perhaps do what i have done in my house.
Thanks a lot to everbody else for their input too
SMILER258
28-09-2015 09:04 AM
