Escort RS Turbo problem.....
just after a bit of help please.
the rs runs mint, no misfire, holds 15 psi of boost, but when you put ya foot down it wont go over 5000rpm any one have any idea on what it is.
already cheacked the timing, replaced plugs and leads, tried a different cam but no difference still the same.....
i'm stuck on this one .....any ideas would be great
thanks
thanks
Originally Posted by jungleistmassiv
sorry mate, thought it was a cossie as per your display pic not an ERST. problems with the metering unit possibly?
got no problems with that one at the min
its just the rst that ive got probs with
i had the same happen to me i think it was the meter unit .my car ws running like that for weeks so i sprayed some wd40 in the meter unit then i went for a drive got on the bypass i slowly put me foot down got to 5000 revs then it started being lumpy so then i put me foot right down and it backed fired and was ok after that ......i changed loads of things because of that.........
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
