Cams for ZVH - maybe one for Jon/Alex
What did was/are you running in your ZVH's???
Is the Piper 285 ok, or does someone like mr norris do a specially profiled came for the ZVH??
yep custom NMS one. Fairly close to a 285T profile. I was previously running a 285T2 cam.
Very very pleased with the cam from Karl. It made boost almost at idle and revved very well.
Was very good value too. drop him an e-mail for a price only took a few days to come too.
Try getting in touch with Piper, they've just sent me a press release for a new cam designed for the ZVH. It's similar to the 285T and is available off the shelf
He supplies followers with it as required. I got anti pump on mine. I wouldn't have thought you'd be revving high enough for solid TBH. A set of anti-pump and double vavle springs should let you rev high enough.
Nick - do they mention what the profile is?
Only info I've got is that it's a modified version of the 285T2.
The part no is ZVHT3.
I did have a spec sheet on it but I've put it somewhere safe and can't find it now
im sure it will rev to that if you';ve got the right components, but its the cam and valvetrain like you say that needs to be sorted- and you need a head to flow the air that high up the revrange to make it worthwhile!
Cheers for clearin that up Jon/Nick/Rolls etc.......
So to re-cap,
Piper cam (with mr Norris's special profile) ZVHT3
Anti pump lifters
Double valve springs
I assume that piper would be able to put the whole kit together
So to re-cap,
Anti pump lifters
Zvhturbo- go to newman, just outside bromley- will do you whatever cam you want, and are apparantly really good quality- ask PFDave as he uses them!- if you need showing where they are gimme a shout!
Originally Posted by TILLIO
Does anyone else know of any other manufacturers of cams other than Kent and Piper for the CVH engine??
Told they are no longer avaliable.
Not after one just yet, however i have a Kent and been told i will be lucky if it last more than 1000 miles, so just keeping my eye out encase it goes tits up.
Ta though
I heard bad things about Newman...
I would 100% recommend Karls cam but speak to him about it he will be able to give you the best advice. Remember the 285T and 285T2 are designed for a standard 1.6cvh engine with standard head and turbo.
Mc5506
05-10-2015 09:57 PM
