A slightly different question on Cossie Brakes & ABS
Hi all
As many who know me know, I have converted the brakes on the cos for some rather good brakes as supplied to me by Tony (RS Nuts) - (Massively happy with these!)
They are extremely good, and generally comprise 330mm fronts with new 4 pots (basically Brembo), and rears to 300mm using original calipers spaced.
My question...
The ABS seems to intefere more now - presumably because the brakes are working that much more efficiently. I cant help feeling the ABS is now not really up to the job.
What have people done about this when upgrading? I know the likes of Trev have gone down the brake biassing route, but thoughts on this?
JJ
My question...
JJ
Interesting feedback.
Yes I had thought of the switch in the ABS system to see how much difference it makes - I reckon the problem may be that the fronts are disproportionately good compared to the rears, though I dont know the ABS system well enough to know how it communicates between the two sets.
JTECH - Look forward to seeing yours after the brakes conversion. Take careful notes!
Interestingly, I found out the other day that ABS doesnt work so well in Reverse.....
JJ
JJ
Testing the future
JJ
Originally Posted by dojj
no need to find the fuses, jut pull the plug out of the top of the resivour cap and be done with it
JJ
Mine has 330AP's, the last owner had a switch put in where the heated seat switch would go on a Saph to turn the ABS on/off. Also has an AP racing brake bias valve fitted but i've never touched it.
Simon.
Simon.
I've binned the abs on my car but am still using the pump. I've powered it using one of the original ABS relays, the pump is switched in and out using the pressure switch that senses the accumulator pressure.
Havn't tried it out to see if it works ok yet, am still building the car up.
Passion for Fords!
one of the problems i had on track was the car nosediving into corners under braking, the rear goes very light and the back is all over the place i know alot is down to suspension set up, but i think it works well if you can get the rear of the car to work slightly before the front so it stays level as the front are alot more efficient
im sure richie B9KOS has a bias valve and his car doesnt nose dive half as much as mine does
An interesting fact i found out about ABS while on a skidpad is... it at least doubles your braking distance when its working.
we did a simulated ice section ,and without abs yes the wheels instantly locked up, but eventually without lifting off the brakes it came to a stop, i couldnt steer, but it did stop.
with the abs turned on ,i hit the brakes, i could steer ,but we actually ran out or runway as the car wasnt even slowing down
Testing the future
snow and ice the stopping distance is longer - nobody said abs can cut your stopping distance and that isn't why it was developed - it is just so that you can still steer
a day on a skid pan is a good way to experience these things before you try and rely on them in the real world
Originally Posted by NUTS RuS
What tyres do you have on James ?
The brakes may now have more bite than the grip level offered by the tyres
Very interesting feedback from everyone though - quite a lot of views on this one!
The thing is whilst ABS aint ideal on the track in ideal conditions, I have in the back of my mind a number of times in bad wet weather that it may have saved me a big bill!
JJ
2Evos & 1 Escort Van :-)
Switch for ABS as per James's suggestion - I turned mine off on track and on for the road.
Same brakes and tyres as you - no problems.
Ford ABS is poor compared to the likes of my Beemer and even my old Calibra which I would never consider switching off.
Si
Si
JJ
borboyous
22-08-2015 11:17 AM
Jack and the Beanstalk
09-08-2015 07:03 PM
Red_bull
09-08-2015 08:34 AM
