what does it mean when a fuel tank is baffled?
i have found some horifying things on my xr2 track car as it dont think th engine was getting enough full up front after close inspection it dont look like there is a swirl pot in the old carb tank and the fuel pump is really noisy.
ive decided to take the whole fuel tank off and put a 3gallon tank in the back alloy one. ive seen a fuel that says twin baffled whatether that means??
can you get racing tank with built in swirl pots?
it means it has plates with drilled holes in/ restrictors to keep fuel around the fuel pump and to stop it sloshing round, to ensure you always have fuel for the pump to pick up not air
Passion for Fords!
if you corner fast ,all the fuel will move to one side of the tank...this may allow the pick up to be out of the fuel ,and there fore not pump fuel...so baffles stop the fuel surging around in the tank... the same idea for baffled sumps
swirl pots remove air from the fuel
