Mira Showers Busted :cry:
The pressure switch has given up and is pissing water all down the inside of the unit and all over the main power cables etc
Does anyone know where a new pressure switch could be sourced? Its a mira 8.4T shower:
Picture of the offending part (note everything covered in water )
Originally Posted by G2.0 RS
kin' hell how old is that shower
Bin it and buy a Mira Sport for around Ł150
Cheers.
Cheers.
And i know Mira is only up the road but they close early on Fridays, was just exploring all possibilities really
Originally Posted by RS Bowk
You are joking arent u Safechav
Mira showers are in Cheltenham just go round there and they will be able to help you.
It did break many years ago not long after we bought it.
Shat it Dazza u slag, u owe me favours for fixing your fuse box
might turn up at yours for a shower
i work for a company called faucets in south wales were are one of the uk largest mira stockest and i am sure that mira sold all the spare to us they had left for the supreme about 3-4 years ago if you can wait till tuesday i can have a look and see if we got any left for you if thats any good?
That would be very good of you! Tuesday is fine mate, its bank holiday weekend not guna be able to do much before then
Re: Mira Showers Busted :cry:
no problem mate will have a look for you if we got one you can pay for it with a bank card and we can send it out for you sould be with you next day
mattyb1981, many thanks mate, all depends on how much it is, if its too much the old man may just want to buy a new shower
Hope not though, i'll be having baths for months
SafeChav
not sure if this helps mate but worth a look even if its a rough idea for prices
http://www.shower-spares.co.uk/mira/mira_supreme.htm
pastyking thanks i'll have a look
EDIT:, just looked and thats spot on, Ł20 so thats not too bad, i'll wait til next tuesday to see hat else is available, but thats given us a good yerdstick anyway
Whats the price on that mate?
Before anything ive got to chop that valve off the pipe and fold it over and check the shower still otherwisde operates seeing as its had all that water over everything electrical
greatly appreciated
greatly appreciated
basically yeah as there are none showing on our stock system and we physically have one here, anything to help out mate you dont realy want to pay for something and it not fix the problem do you?
thats very good of you mate, but at the same time i don't expect something for nothing, and Ł10 is better then Ł20, you can have the tenner yourself if you like
As long as you're sure mate, a tenner is nothing, additional to the fact its the old mans shower and not mine so i have absolutely no quarms about giving you his money
if u are going to get a new shower make sure ur supply is up to the job judging by the photo its 6mm = t/e so u should be ok for a slight upgrade kw wise, but the last thing u want is to run a new 10kw shower on 2.5 mm t/e if in doubt get your old man to get it checked out water n leccys dont mix as i found out once at work
hth
hth
vroooom ptssssh
gasants - fuck you who are you to judge me
v6matt, the shower is working again now, bit of a temporary cobble until the new part arrives. And thanks for the advice but should it ever get changed the wiring will be taken into consideration, i was an apprentice electrician a little while back
