Did ford ever make
Did ford ever make
did ford ever make a capri 4x4 model as i dont think they did but a bloke i was talking to last night swears blind they did
Yes ( I think- or they might have been an aftermarket option) has definatly been covered in classic ford.
I believe they used a ferguesen 4x4 system.
Rocking horse poo is rarer than these though....
Happily retired
Yes their was a system, I remember them being used in their Autocross Capris.
The cars were very quick, but the system was very un-reliable & often broke.
seem to remember a few years back, a 4wd S2 escort turbo, prototype thing as well, from ford?
definitley rallycross/autocross 4wd capris
didn't they have 3.4 quad cam V6s?
escos prototype was the saff 4x4!
rs1700t was rwd, turbo'd mk3, not mk4
In the late 60's/early 70's ford made a limited number of mk1 Capri's for use in rallycross.
I think John Hill who runs Capri Club International was restoring one.
Found this article if you can translate it:
4x4-Capris für Rallycross [Bearbeiten]Beim damals noch jungen Autosport namens Rallycross setzte das Werk in England zwischen Anfang 1969 und Ende 1971 selbst zwei Capri 3000 GT 4WD (mit Zodiac-V6-Motoren) unter Rallye-Werksfahrer Roger Clark und seinem Bruder Stan Clark ein und unterstützte außerdem noch das Semi-Werksauto von Rod Chapman. Die am Ende gut 250 PS starken 4x4-Capris (mit 3-l-Motoren, CanAm-Benzin-Einspritzung, ZF-Getriebe und Ferguson-Allradantrieb ausgerüstet) hatten anfänglich zwar mit vielen „Kinderkrankheiten“ zu kämpfen, wurden aber irgendwann so überlegen, dass sie erst fünf oder zehn Sekunden (4WD penalty – abhängig von der jeweiligen Rennstrecke) nach ihren Gegnern starten durften und trotzdem oftmals siegreich blieben.
Quick translation,i think !!
4x4-Capris for Rallycross [Work on]
With at that time still recent autohaven named Rallycross the work inserted 1971 even two Capri 3000 GT 4WD (with Zodiac-V6-Motoren) into England between at the beginning of of 1969 and end in addition under Rallye Werksfahrer Roger Clark and its brother Stan Clark and supported the Semi Werksauto of Rod Chapman. The 4x4-Capris strong at the end well 250 HP (equipped with 3-l-Motoren, CAN to fuel injection, ZF-transmission and Ferguson all-wheel drive) had to fight initially with many „to teething troubles “, became however sometime so superior that they only five or ten seconds (4WD penalty - dependent on the respective racing course) after their opponents to start were allowed and nevertheless remained often victorious.
sources [Work on]
Oswald, Werner: German cars 1945-1975. Engine book publishing house, Stuttgart 1976.
Web on the left of [Work on]
sources [Work on]
markk
18
17-08-2015 05:19 AM
track.focus'd
12-08-2015 05:53 PM
