*******MIKE RAINBIRD*******
#50
Top one is the first graph, then second one is the boost being turned down 2 psi. 3 rd one is with both graphes and the fuelling added.
320.7 BHP 362.8 Torque
#52
I no loads a lines, Learnet that you carnt set up a cossie on the rollers, as the car runs 2 psi more on the road, the first run at 24psi, on the road it was 26psi lol
Think that one is with power at the wheels and the drag on transmission
#54
not sure, so we hooked the car up again to see if there was a difference in my gauge to theres, but the nomad gauge is spot on, dnt no why it was, set up to 24psi on the rollers then on the bypass it was peaking at 27psi???? Not sure pal
#55
when was this doen Matt?
as I seemed to have guessed the result a day before it happened!!
Anyone want tonights lottery numbers??
#60
TT T38 Power
Im happy it didn't blow up
Steve.
#68
dnt think my new engine would handle it,
car now has no throttle responce when I have let off then bk off its like there is no fuel there 4 a spit second cluelees on that.
#70
Well lol. dnt no what to do with it to be honest. diff if a little noisy lol. Well leat I no that live mapping is by far the best way lol.
#71
Hey Bullet,, 32psi On a t3, wats injecters, I wonder if Greens would feul, 29psi, but only midway through, and then a serious drop in boost.
#76
car takes off like a rocket, Got Rollers on SAT,, gonna run it up in 5th gear this time, try to put more strain on car, runs 2 psi more in 5th on road. 12 evos 1 cossy.
******* I WILL FLY THE COSSIE FLAG********
#78
They run them in 4th
But am gonna ask them to run it in 5th, as it runs more boost that way, plus I allready have the read outs wen run on 4th only 2 months ago etc.
#80
air colder on the road, ore dense
canrt get air flow u can in 5th at 90mph on the rollers,
rollers dnt provide enough strain as wat road does??
