piston liners
Old May 1, 2007 | 11:26 AM
zvhrst's Avatar
zvhrst
Default piston liners
i have recently destroyed the focus engine and needs reboring, trouble is ive been told they cant be done, BUT... one company says they can over bore it and fit a liner so i can use std pistons,
anyone think this is a bad idea??
Old May 1, 2007 | 12:14 PM
phil_focus's Avatar
phil_focus
so you have propper killed it then???
Old May 1, 2007 | 04:12 PM
danneth's Avatar
danneth
TORQUE!
yup its not a in a good way
Old May 1, 2007 | 04:17 PM
Bore + liners, cheaper to get another block ?
Old May 1, 2007 | 08:35 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
I personally had a liner in my 470 bhp Cossie engine.
No problem at all.
Price things up and see how they compare. Done right, a liner is a perfectly acceptable way to repair an engine.
Si
Old May 1, 2007 | 09:18 PM
focusv8's Avatar
focusv8
What engine? R.S, as sig?
Old May 1, 2007 | 09:46 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
nowt wrong with fitting liners, people have been fitting them to recon engines for years with no real problems
Old May 2, 2007 | 07:56 AM
zvhrst's Avatar
zvhrst
its a focus RS by the way,
yes its destroyed, melted number 2 & 3 pistons, and its damaged the bore pretty bad,
to fit 2 liners am looking at £60 per liner,
obv + pistons ect,
but i can get a new short block built up and fitted into car for around £2k from collins
i think this is the option i am going to take tbh
Old May 2, 2007 | 08:03 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
what was the cause of the engine failure?
Old May 2, 2007 | 09:15 AM
Garage19's Avatar
Garage19
Why can't you simply rebore?
Who told you that you couldn't?
Is it due to the lack of oversize pistons?
Look at pistons from the states for zetecs. They do several oversizes.
A rebre and set of forged pistons should set you back £500 if you can do the work yourself.
Old May 2, 2007 | 12:00 PM
zvhrst's Avatar
zvhrst
still unsure why it failed at min,
i am thiunking injector fault as the engine was std,
i have been told by a few companys i cant rebore them
Old May 2, 2007 | 02:43 PM
Garage19's Avatar
Garage19
Thats bolocks.
Its just a zetec block and i have had a few of them rebored.
You can get 1mm oversize pistons from the states so unless you have done more than 0.5mm damage to the bore, which i doubt, you will be ok.
Old May 3, 2007 | 08:27 AM
zvhrst's Avatar
zvhrst
thanks for the info mate
jessie_rs
62
Aug 6, 2019 09:27 PM
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
ajamesc
Sep 8, 2015 06:51 PM
