stealth gauges. need help!!!!!!!!!!!
Old Feb 16, 2007 | 06:26 PM
b_kennedy's Avatar
b_kennedy
Default stealth gauges. need help!!!!!!!!!!!
I got 3 stealth gauges for my mk4 RST. Im assuming they have to be wired to ignition live rather than illumination as they are obviously stealth.
Can I take a feed for all 3 from the same ignition live point or is this bit dodgy. Many thanks
Old Feb 16, 2007 | 06:30 PM
tommyt's Avatar
tommyt
should be ok just put an inline fuse in to be on the safe side
Old Feb 16, 2007 | 06:32 PM
b_kennedy's Avatar
b_kennedy
so it wont melt then
Old Feb 16, 2007 | 06:34 PM
tommyt's Avatar
tommyt
what live point were you thinking of using
Old Feb 16, 2007 | 06:38 PM
b_kennedy's Avatar
b_kennedy
you know the yellow ignition live on the barrel then goes to a grey connector and joins rest of the loom?? After that connector i was gonna run wire from there then take 3 feeds for each gauge.
Old Feb 16, 2007 | 06:46 PM
tommyt's Avatar
tommyt
sound no probs you will have to put some pics up when its done p.s. run as low rate fuse as you can about 7.5amp should be fine, im running a 5amp for 2 gauges.
Old Feb 16, 2007 | 06:48 PM
b_kennedy's Avatar
b_kennedy
cool. Thanks fella for your help. Most appreciated!!!
Old Feb 16, 2007 | 06:52 PM
tommyt's Avatar
tommyt
no probs thats what were here 4
Wilsfoci
15
Mar 30, 2016 10:26 PM
mint_s2
Sep 2, 2015 08:58 AM
sapphireman1
Oct 22, 2005 11:44 PM
lockesRSparts
49
Jun 8, 2005 02:28 PM
