Wheel HP - Dynojet Rollers.
Right, confused.
I've got two rolling road print outs, one from Minisport, and one from Awesome GTI.
Awesome GTI use "Dynojet research" rollers, now my wheel hp figures, differ , MASSIVELY.
Minisport was 81whp and 109lbs/ft torque. (117bhp)
Awesome GTI was 97whp and 104lbs/ft. (114bhp)
Both same mods, and both around the same temperatures.
What's going on? and why do the wheel hp figures differ so much?
well up the tyre pressure 10 psi and the BHP reading will go up! So its pointless to talk about WHP.
To measure work done (HP) you use a brake against the engine...
One of the methods above uses the tyres to transfer the power to the roller, where as the other directly bolts to the hub removing that link.
Hence the two figure must be different. but once you look at the calculated flywheel figure it all evens out
Alex
Alex
the tyre sits in the rollers
hence there are TWO contact patches.
If you up the pressure the side walls can support a greater load and hence the tyre will defect less. This effects the run down calculation(where the engine is disconnected and the momentum of the drivetrains runs against the force of the rollers and slows down).
Alex
Alex
thats right Alex...when i want more power i just pump my tyres up
Why are you moaning over 3hp anyway? Every RR will be subject to hysteresis losses, especially if there has been a lack of maintainance. no two RR's will ever give the exact same output, unless they were calibrated using the exact same machinery at the exact same time and were both upto the same service standards.
JAmes.
JAmes.
JAmes.
JAmes.
It seems every run at Awesome GTI is high up on WHP figures......
IIRC Awesome GTi use a single roller setup...
arr look it is
As the car accelerates against the force of the RR it climbs up the roler (thus compressing the tyre hard against it as the vehicle is strapped down).
On overrun you let off and the car drops down the roll and releases some of the pressure on the tyres - thus changing the way you are measuring what is happening.
Alex
arr look it is
Alex
focus rs 1672
need to edit my sig to read 214@wheels@18psi@26psiTP(tyre pressure)
Originally Posted by BatFink
Is this what Dave Walker was trying to mean in PPC this month, Alex?
But I haven't bothered reading that article yet - but I would hope so. He's a knowledgeable guy and I've had some very good conversations with him about RRs in the past!
Alex
Steve.
Each power point held for a minimum of three secs to stabalise then recorded.
This is the most accurate way IMO....
if all else fails i get the foot pump out
Re: Wheel HP - Dynojet Rollers.
Originally Posted by YoungDan
Right, confused.
I've had various wheel figures from various RR's but most tend to be similar once calculated into flywheel figures.
I got
414bhp whp
490bhp flyhp at nobles.
i then upped the power slightly which was guessed at 10-15bhp and then went on at awesome...
482bhp whp
502bhp flyhp
So not too far out overall.
yeah only power at the wheels...
everything else is a guess by a computer
After all you can't measure BHP - you calculate it!
BHP = (torque x rpm) / 5252
BHP is brake horse power
Alex
Testing the future
Right, confused.
I got
414bhp whp
482bhp whp
502bhp flyhp
i cant argue Alex as i cant put what i mean into words
sorry....
each to their own
sorry....
each to their own
There are pros and cons to ANY measurment method and at the end of the day they are all fairly compairble! To get serious about it you need a dyno and FFS lets not get started on those or people with little knowledge will shout TUV TUV TUV TUV TUV TUV TUV TUV TUV TUV TUV
Right, confused.
I got
414bhp whp
482bhp whp
502bhp flyhp
Note to self... learn to read
Sort of makes my point valid though...
I also cannot believe why some rollers recon trans losses should be so high.
For instance... my car lost 76bhp at nobles
Why so much?? if a 2.0gls sierra went on with around 90bhp std with a 'similar' trans setup it would only have around 15bhp left to move the car... doesnt make sence.
Now i know its meant to be a percentage of the output type of thing but i just cant see that it should be to the extents it is.
A gearbox takes x amount of power to drive it.. Fine
why does it need more power to turn it if you put more power through it? and surely on that priniple it would mean you would actually lose more power the heavier your car was? (if you get what i mean)
If a gearbox was sealed and hydrolic i could understand it more but it isnt.
the harder you turn the cogs... the more power they absorbe doing things such as making noise and pushing themselves harder into the bearings.
hence its a percentage thing rather than a simple loss figure.
Alex
Alex
I'm glad. i know what i mean to say but just struggle to get the words across through a keyboard sometimes
Its a subject that has puzzled me for a long time and the best i can come up with is that trans losses have been worked out like this for alot of years... but with all the disbelief in rolling roads anyone who dares to question the workings would get shot down.
Lee
watch me get shot down now for suggesting such an outrage
Lee
Alex
Alex
for example... The shaft pushing onto a bearing so hard it collapses the bearing and digs itself into the alloy casing and starts gouging it away... how many bhp would that actually take?? a cheapo 12v cordless with a smooth round bar in place of a drill bit could chew up part of the casing without too much trouble etc... and what power would they make? 0.01bhp???
All the above is just an example btw,
Read the last paragraph from the first document and the first paragraph on the second document
http://www.factorypro.com/magazine/S...e/scan0002.pdf
http://www.factorypro.com/magazine/S...e/scan0003.pdf
that make of Dyno is regarded at 15% overoptimisitic
Adam Graham
06-09-2015 06:04 AM
