need a welder advice please..........
got a project mk4 cabby in a garage in town and the garage has no electricity or water, bought meself a 2.4kva generator, tried using my arc welder to run off it but not enough power , does a mig welder use less power? and if so which one do i go for gas or gassless?
any advice would be gratefull!
cheers in advance
cheers in advance
dont know whether its me bein thick but ive got a fook off big genny but it wont even run a little arc welder, so a mig with gas is the way to go then
whats the difference ?
cheers peeps!
cheers peeps!
Originally Posted by GARETH T
wire the welder to the street lights
As Gareth said the gas mig's are much better as you can adjust the gas valve to suit your welding & the gasless wire doesnt come cheap either & tbh its pretty crap.
Ok for welding in windy conditions i suppose but thats about the only advantage
mig with gas is the way to go also use argon gas if u can get it co2 dosent give sutch good results.if u still want to use a arc welder try and find an inverter one as they draw a lot less current
cheers for all the replies guys, if i cant find a welder that will run off this genny im gonna be well screwed!
looking for an arc with an inverter then, the hunt goes on...........
Mark.
Mark.
can anyone find me an inverter arc welder on the net that will run off a 2.4 kva genny?
also how do i convert kw into kva?
use them both as the same unit mate (there or there about)
cheers for the links focusv8 very handy, like the bottom one i take it that would work with my genny then? , thanks for all your help
mk3ste
17-10-2021 10:09 AM
Mc5506
05-10-2015 09:57 PM
rsguy
44
29-09-2015 03:29 PM
