oh bugger no code
Old Dec 22, 2006 | 08:14 AM
righthooker's Avatar
righthooker
Default oh bugger no code
i need to change the battery on mu 02 transit ,i have looked all over the paperwork for the van and the key code for the stereo is not there
sugestions please
Old Dec 22, 2006 | 08:17 AM
righthooker
just seen a post further down which may be of use
Old Dec 22, 2006 | 08:19 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Sing to yourself
kjc300's Avatar
kjc300
what stereo is it??
if the serial number starts with an "M" and 6 numbers I can get the code straight away.
Old Dec 22, 2006 | 09:26 AM
S3an's Avatar
S3an
Originally Posted by kjc300
what stereo is it??
xmas spirit is all around us
Old Dec 22, 2006 | 09:34 AM
righthooker
looks like the code wont be a problem,put on the new batt and thr radio was fine
Problem is the van wont start,so i went and got another one ,and it wont turn over .am i missing somthing here as its only a bloody battery
Old Dec 22, 2006 | 09:37 AM
Rhys's Avatar
Rhys
PMSL fookin things
Old Dec 22, 2006 | 09:41 AM
righthooker
it aint funny as i need to go out in the fooker ,and i lent my other van to a freind yesterday till yhe new year
Old Dec 22, 2006 | 09:52 AM
plynchy's Avatar
plynchy
Starter motor mate?
If you can see it, twat it with a broom handle or similar while Si/Ste holds the key as if to start it, it may be sticking.
Are the battery terminals clean & tight?
Old Dec 22, 2006 | 09:53 AM
righthooker
clean as a whistle ,will try to to sort it when i get back from shopping but then i have to go out on the lash at 2
Old Dec 22, 2006 | 11:55 AM
MrMPuk's Avatar
MrMPuk
What was the reason you changed the battery?
Old Dec 22, 2006 | 12:00 PM
righthooker
because over the last week it has been suffering due to the cold weather mate ,and it then gave up yesterday hence the new one
Old Dec 22, 2006 | 12:02 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i just bought a new battery for the missus puma, fook knows where she put the paperwork for the radio code, but i guess if oyur quick enough to change them over then its ok is it?
fookin cars
Old Dec 22, 2006 | 12:05 PM
Stu.H's Avatar
Stu.H
Why not get another battery, daisy chain them, then remove battery ur gonna be using connect new one up, remove old one?
Thats what I would prolly do...
Or use jump leads to another car
Old Dec 22, 2006 | 12:06 PM
DangerousBryan's Avatar
DangerousBryan
sure its not the starter motor mate? they are notorious on new transits for fucking up.try it with jump leads,if its still the same then it can't be the battery.
bryan
Old Dec 22, 2006 | 05:20 PM
MrMPuk's Avatar
MrMPuk
Right if the van was struggling to start it was probably due to a bad connection on the starter which when hot isn't a problem but due to the cold the resistance increases, when it finally gave up the ghost it was probably caused by the starter fuse blowing due to the extra current being drawn because of the extra resistance.
Old Dec 23, 2006 | 09:49 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
done the puma, needs the radio code
Old Dec 23, 2006 | 11:21 AM
bigneck's Avatar
bigneck
i can give you the radio code now if your quick enough
all i need is the serial number down the side, ont he ford big radios it begins with M then some numbers
Old Dec 23, 2006 | 04:18 PM
righthooker
So the answer to get it going is???
the starter is only 6mth old by the way
Fiddy
21
Sep 29, 2015 06:10 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
