any engineers about?
got a 1/8" sensor that i need to make a thread in my inlet manifold. The metal is about 5mm thick, so i have brought a 1/8" tap, what size should i drill the hole to before tapping it? would be easier if i could drill a hole measured in mm as i have the sizes here. Cheers
ok i will probably test it on a spare piece first, the sensor is made of what looks like nylon? What is the best way to insure this is sealed well as it will be on my FRS, is there some kin of paint you put on the thread first or should screwing it in do the trick.
Originally Posted by wirralphil
where's me zues book......
gotta love the zues book,,, for anyone who hasnt got one ! GET ONE
Monte 087
Tis actually "Zeus" but im splitting hairs.
To be as accuratte as i can be,after a few beers,you take the addendum and dedendum of the thread and adding them up thus giving the thread depth or .86603xp to give the fundimental triangle minus the basic crest radius,minus the basic root radius.
Take about 2/3 of this depthx2 then take this figure away from the tap diameter, that should be about right for the hole size to be drilled.
And yes i make all sorts of threads,taps,cutters milling hobs yada,yada,yada.
