If it doesnt work properly this time its going
Did a headgasket on the saff the weekend, solved the engine cutting out and the pressurising of the cooling system. But when head was off I checked for flatness and it was slightly out right at the front, thought it would be ok as it wasnt a problem before, now oil is spraying out of the head.
So come home from work early, got 3 hours to get the head off stripped and over to be skimmed, and when it goes back together if it's not right this time she is going and I am gonna buy a real car.
Steve, I dont have another one I was not sure if the one that went on yesterday will be ok, even though its been compressed? Will the new headbolts be knackered as well
Originally Posted by avengerpenguin
measure up what???
Then yes, I would be wanting to put another one on - I have the late esccos one spare, there are a few well known people who say it's fine for stg3 (it's what I have on mine) and the best part is they are like 15 quid (maybe less )
yes no point in doing anything if its been skimmed to much , you might as well put it on ebay
the people who skim your head will have the equipment to measure it up
well its going to have to come off, so I better get on with it the wife is going to work at 6.
Once its off can I get back to you about the gasket and bolts
I can bring them round for you tonight if you want that mate - just let me have something close to what they normally cost (we can have a look in the magazines) Saves you messing around with delivery etc.
edit Just found the min thickness - 138.68mm
Right its off not a bad considering I had to work in a thunderstorm, under 2 hours. Steve that would be good if you could drop them round I will have to try and get to the cashpoint before she shoots off to work.
Measured the head and I made it 139.5 does that sound right??
OK mate, I'll call in later.
Measurement sounds about right, but take it in a couple of different places as well. So, whoever skims it, tell him no less than the 138.68mm and you should be fine.
Under 2 hours outside - good job
steerfromdarear
28
29-01-2016 06:14 PM
